Dexter MH electric brake replacement
   / Dexter MH electric brake replacement #1
22x
Rosemount MN
N/A
Hello,
I just bought a trailer that has 6k Dexter Mobile Home axles on it & the electric brakes are all rusted & need to be replaced. Can anyone confirm that the brakes are 12 x 2? I believe they are from all of the research I've done.
Has anyone ever replaced brakes on these? Since the brake backing plate is part of the axle, I don't believe you can replace with a complete brake assembly - but you can replace all of the individual components, i.e., pads, springs, magnet, etc. Can anyone confirm this?
I have called both Dexter & etrailer.com & neither of them have given me a straight answer :)
Thanks
Doug
   / Dexter MH electric brake replacement #2
Measure the bolt pattern on the backing plate. Chances are, standard 12x2 trailer brake assemblies will fit or can be adapted.
   / Dexter MH electric brake replacement #5
The last time I replaced brake shoes I had to bring a set down to the local trailer place and they had a book and just matched up the brake to an outline. I've heard that companies like Dexter don't like to sell brake parts for their MH axles as a way to prevent people from using them to build trailers. That's why they weld the backing plate onto the axle. I think what I would do is measure the inside diameter and width of the drum buy one of the complete bolt on assemblies, they are pretty cheap. Then I would see if I couldn't adapt it to work. If you can then you'll never have to worry about getting brake parts in the future. Another option is to call a mobile home place. Around here they sell the axles for $100 the last time I checked. You could find you can replace the whole thing for the same price as buying replacement brakes.
   / Dexter MH electric brake replacement #6
Before you spend the money does your state require inspections? If so it may not be a legal trailer due to the MH axles.
I work on trailers part time and we will not touch MH axles due to liability. Also many customers are from a state away that require inspections and they have had issues.
Chris
Chris
Not that I'm aware of. This trailer is actually a snowmobile trailer, so it only get's used 4-5 times a year. I've been able to identify all of the parts I will need to replace the brakes.
Thanks
Doug
I am finally getting back to this project - too many other things going on:)
I have taken one wheel off & taken off all of the old brake parts. My next step will be to grind/cut off the old backing plates. I am trying to determine what size backing plate I need. Does anyone know what size axles they are? Based on everything I've read I think 3", but am not sure.
Anyone?
Thanks
Doug
   / Dexter MH electric brake replacement #10
Is your plan to remove the backing plates and then weld these on?
Brake Mounting Flange for 3" Round Axle Redline Accessories and Parts 4-44-1
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2024 Big Tex 14GN-40D5A 35ft Gooseneck Flatbed Trailer (A51691)
2024 Big Tex...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2000 Chevy 3500 Wrecker Truck (A52384)
2000 Chevy 3500...
2013 ISUZU NPR STAKE BODY TRUCK (A54313)
2013 ISUZU NPR...
