Dexter MH electric brake replacement
   / Dexter MH electric brake replacement #1
22x
Rosemount MN
N/A
Hello,
I just bought a trailer that has 6k Dexter Mobile Home axles on it & the electric brakes are all rusted & need to be replaced. Can anyone confirm that the brakes are 12 x 2? I believe they are from all of the research I've done.
Has anyone ever replaced brakes on these? Since the brake backing plate is part of the axle, I don't believe you can replace with a complete brake assembly - but you can replace all of the individual components, i.e., pads, springs, magnet, etc. Can anyone confirm this?
I have called both Dexter & etrailer.com & neither of them have given me a straight answer :)
Doug
   / Dexter MH electric brake replacement #2
Measure the bolt pattern on the backing plate. Chances are, standard 12x2 trailer brake assemblies will fit or can be adapted.
   / Dexter MH electric brake replacement #5
The last time I replaced brake shoes I had to bring a set down to the local trailer place and they had a book and just matched up the brake to an outline. I've heard that companies like Dexter don't like to sell brake parts for their MH axles as a way to prevent people from using them to build trailers. That's why they weld the backing plate onto the axle. I think what I would do is measure the inside diameter and width of the drum buy one of the complete bolt on assemblies, they are pretty cheap. Then I would see if I couldn't adapt it to work. If you can then you'll never have to worry about getting brake parts in the future. Another option is to call a mobile home place. Around here they sell the axles for $100 the last time I checked. You could find you can replace the whole thing for the same price as buying replacement brakes.
   / Dexter MH electric brake replacement #6
Before you spend the money does your state require inspections? If so it may not be a legal trailer due to the MH axles.
I work on trailers part time and we will not touch MH axles due to liability. Also many customers are from a state away that require inspections and they have had issues.
Chris
Chris
Not that I'm aware of. This trailer is actually a snowmobile trailer, so it only get's used 4-5 times a year. I've been able to identify all of the parts I will need to replace the brakes.
Doug
I am finally getting back to this project - too many other things going on:)
I have taken one wheel off & taken off all of the old brake parts. My next step will be to grind/cut off the old backing plates. I am trying to determine what size backing plate I need. Does anyone know what size axles they are? Based on everything I've read I think 3", but am not sure.
Anyone?
Doug
   / Dexter MH electric brake replacement #10
Is your plan to remove the backing plates and then weld these on?
Brake Mounting Flange for 3" Round Axle Redline Accessories and Parts 4-44-1
Impact Attenuator Guard Rail (A51692)
Impact Attenuator...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
JOHN DEERE 635F 35' HYDROFLEX PLATFORM HEADER (A51247)
JOHN DEERE 635F...
2013 Kia Soul Hatchback (A51694)
2013 Kia Soul...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
