Dewalt table saw at lowes
   / Dewalt table saw at lowes #11
there really is not much to a table saw. i would pay more attention to the actual physical top of the table saw and make sure it can not warp or like, and then any sort of slide out mini supports. and then also the "rip fence" make sure it will not easily break if you accidentally drop it, and that you can adjust the tension on it.
Shop Bosch 10-in Table Saw at Lowes.com
went more like with above table saw from master force, with fold up wheels... i wish i went with a different wheel set. dragging the table saw up and down stars when folded up :/ the wheels do not stick out far enough. and end up catching in a few spots. i also have a couple little over steps getting into some doors at shed and house. that get caught up.
overall though. quick and fast to setup, and easy to stabilize it. and it packs away nice in the shed being able to stand it up on its side via the fold up legs/wheels on it.
some folks want dust collectors, and you might want to pay extra attention to that, if that is your goal for placing unit in a shop. some of the units i looked at a few years back. just had ugly collectors on them.
90% of time i do not have the guard on the table saw blade. due to ripping stuff to small, or just the right size to get hung up in the guard. some of the setups the guard is just down right pain in rear to use, if ya lift it up and out by accident, you may have to spend a few minutes putting it back in. or how you adjust the guard is just plain one of those what in the world were they thinking?
it would of been nice to have a 12 inch blade. but costs, motor size / amps, ya start getting limited.
datto blades, if ya into making furniture and like, and want different joints. double check how wide you can insert a datto blade set..
i tend to always end up needing a pusher stick. to push things rest of the way through table saw. i could care less about "storage" of the table saw and some plastic pusher stick that looks all nice on the table saw in storage, but rather, some sort of U shape half pipe or like i could toss a stick into, for easy grabbing. i have a large light weight tool box i toss most stuff into, for table saw, when put into storage.
   / Dewalt table saw at lowes #12
Current issue of Fine Homebuilding has an article about the Bosch and Dewalt's. I have a Dewalt portable I bought back around 97 or 98. I am not a contractor but have used the saw while working on several properties including farms. Read that as used hard and put up wet. Though I am mainly a Milwaukee and Bosch fan, I have no major complaints about the Dewault. Even dated, mine has the geared adjustment on the fence which I have found to be excellant.
   / Dewalt table saw at lowes #13
I have the smaller Dewalt portable saw and for knock about job site use has been very satisfactory. No way does it compare to my shop Powermatic 66 table saw but the Dewalt has given good service and doesn't mind being rained on occasionally.
The miter gauge is kina funky but that's what chop saws are for.
   / Dewalt table saw at lowes #14
I have this Dewalt and use it a lot. Very good saw and light to carry.
I did not buy the stand , I always install it on my two sawhorses with half a sheet of plywood and it works fine for me.
   / Dewalt table saw at lowes #15
I have a semi portable Grizzly table saw that looks like it would mount on that Bosch stand. I don't like the caster wheel stand my saw is on, I like the wheel barrow style better.
   / Dewalt table saw at lowes #16
No experience with portable table saws as I have a fairly large stationary saw. I do have a portable panel saw that works great for portability. A regular circular saw mounts on a square piece of steel that slides down two extruded rails. It cross cuts up to 48 inches and you can turn the steel plate 90 degrees, lock it down and feed sheets thru it. The legs fold together and it leans against the wall taking up maybe 8 inches of room. I made some saw horses the same height to help with 4x8 sheets.
I take it and a generator to spots with no electricity and can make just about any type of cut.
Just another option if you ever see one. Mine was second hand for like 60 bucks. One of my favorite tools.
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A55315)
2017 Cadillac...
2018 John Deere TX (A53317)
2018 John Deere TX...
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A58214)
2014 DRAGON...
Butterfly Artwork (A55758)
Butterfly Artwork...
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
