Dewalt generators ??
/ Dewalt generators ?? #1
TOMLESCOEQUIP
Platinum Member
Strasburg, OH
My brother in Florida is looking into the purchase of a back-up generator. The model He's looking at is an 8hp honda powered unit of around 4000 watts.total, with outlets for both 110/220 volts. Does anyone know who makes the generators for dewalt?? Anybody used a dewalt extensively on the job to give an insight as to their reliability ?? a site on the net has one for $1399. with free shipping, a free 4 1/2 " grinder, & a $40 coupon (instant discount) for a net of $1359. delivered. Thanks in advance............Tom http://www.toolking.com/dewalt/view.asp?id=6015
/ Dewalt generators ?? #2
The Dewalt generator is fine. It's well made, I have no clue if Dewalt simply has them made or designs and builds theirs. It's a clue to me that it is a decent quality generator when it uses a commercial quality Honda. The Dewalt, unlike a similar HP Honda uses a brushless design. The benefit is higher current ability, the drawback is as it was explained is a higher idle down speed. I would certainly consider it myself if I was in the market. I almost had a 4500 watt Dewalt from Amazon.
/ Dewalt generators ?? #3
If he's using it as a backup then look into a inverter type.I use nothing but Honda's.The db rating sur makes it more tolerable to listen to for a long time.Tell him to check Mayberry's
/ Dewalt generators ?? #4
I had the 3000i. Super quiet. I did not care for its inability to start heavy loads like Skillsaws without having to be in full throttle mode. Even at full throttle it is quiet.
/ Dewalt generators ?? #5
If your talking about the EU3000i.I run all sorts of saws/hammerdrills/impacts/metal hole punchers/magdrill off of mine with no problem.They are so quiet that it almost takes getting use to.
/ Dewalt generators ?? #6
It (EU3000i)will run low amperage devices no problem from the idle position but high current stuff it has an issue with. The manual even mentions this and suggest you flip idle down to off with high current devices like a skill saw. It just won't get up to full power otherwise.
/ Dewalt generators ?? #7
The brushless does not offer any advantage in output current, since the brushes are only carrying the DC excitation current. Brushless designs offer the advantage of...no brushes. Brushes are , of course, a wear item. The downside to brushless is only an increased complexity (diodes mounted on the rotor and an additional stator winding on better designs), and depending on how it was designed it could have a lower output at lower speeds, which is normally not a consideration.
paul
/ Dewalt generators ?? #8
Thanks Paul for that info. I asked about this from a generator person who sold generators with no brushes, in other words, no Hondas. Here is a place one can go for more info. Generator FAQ's
/ Dewalt generators ?? #9
If he's going to buy a contractor grade portable generator for emergency backup power then there is no need to spend 1400$ for a 4000 watt generator. My trusty coleman powermate is powered by an 11 HP tecumseh engine and throws 6850 peak watts and 5500 continuous. It is loud, but so are all construction generators, and we are talking about emergency backup so it doesn't matter. He can't run a home central A/C unit with these generators, he will need mucho wattage for that. The coleman has a 5 gallon fuel tank and runs along just fine. It has been very dependable.
Generac makes the famous 4000XL that has been around a long time with pressure lubrication and an oil filter.
Time to shop around. Go to the home depot or even Costco. Has the discussion about wattage been had? Do you know you need 4000 watts. Are we lighting lights and running a fridge or trying to run the A/C?
Unless you spend the big bucks for a super quiet generator like a Honda, you may as well go the cheap route for a loud generator. Anything in the middle is a waste of money.
/ Dewalt generators ?? #10
I agree Joe. If your using a generator on a jobsite though, I would argue that the many hundreds if not well over $1000 you spend on a quiet generator is well worth it. Drawing from my many years of experience in construction, nothing is more intrusive into your many hours of construction work then the continuous roar of a loud generator. I wonder what detrimental effects it has had on folks frame of mind since when lunch time hits, the first thing we do is kill the generator and all comment how incredible it is to have the stinkin thing off!
His original choice was the honda. He really wants a honda engine & was looking for more quality in the generator section than some of the lower end units.
/ Dewalt generators ?? #12
For lower wattage uses and a nice quiet generator with a Honda name on it, don't dink around. Get the real Mc'Coy, the ridiculously quiet EU line from honda has very clean power and the Honda reputation. You can use these generator for much more than backup emergency power.
A quiet generator is always better than a loud one but there is very little in between. You pay for that quiet. Most of the time it is worth it but sometimes it is not, one of the times it is not worth it for me is when you are talking about high wattage and/or emergency needs.
Again, depending on the use of the power made by the generator it may not matter how clean the power is. If he is running a computer with this power source then I would again recommend the Honda EUi line for clean steady power. A contractor generator like the dewalt won't have a waveform as clean, frequency as steady, or voltage as consistent as the honda inverter series. Running a light bulb,well pump, or fridge is within the tolerances of most any generator out there.
</font><font color="blue" class="small">( Running a light bulb,well pump, or fridge is within the tolerances of most any generator out there. )</font> Basically that's what its going to be used for.......I guess he really wants a little better quality than the box store units after reading some of the experiences people have had with (some), not all lower end units.
/ Dewalt generators ?? #14
Have used the Honda EU series for several years now........TOTALLY dependable.....Yes, one has to take it off of idle when running a welder out in the field.
I mainly use it for going into the back country with my Airstream and there it is fantastic. Folks around me at campsights are amazed that we even have a generator running as they dont hear it...........It powers that A/C just fine while using the other appliances............Gas consumption is about a 5 gallon can of gas per day.....or less..........
NO it will not power 220 by itself............one hooks up a second generator in series for this......Honda provides an accessory wiring harness to do this............I honestly dont know if it provides enough power even then to run a well pump or home A/C...........Dennis
/ Dewalt generators ?? #15
Hooking the two up does not give you 240V. It simply gives about twice the wattage. The hook up simply synchronizes the two generators. On the other hand, there is the EU7000i, it's 120/240V and is very quiet. I tried using my Honda EU3000i with my little Millermatic MIG 90, but it just did not have enough. I now have a Honda 3500watt contractor type. It does have 240 and can easily run my 240V well pump.
/ Dewalt generators ?? #16
They make 110 volt well pumps and this may be a consideration for the next time you replace your pump. Your home AC needs mucho power. More than most any portable generator can put out. A PTO generator would be the ticket for that.
A Honda EU2000i can be purchased from Mayberry's for less than 900$ delivered to your door. This sounds like the best option for your friend unless he needs 220 to run something.
/ Dewalt generators ?? #17
You know, I really like the idea of these new constant pressure well pumps. The Honda EU 7000i looks like it would be a wonderful backup generator. Not only is it quiet, but for those not familiar with inverter type generators, the engine only runs as fast as it needs to. It can be at idle to full RPM and generate full 120V and/or 240V. The wonderful thing about the EU3000i is that even at full RPM it is quieter then almost any thing else that is at idle. It is that quiet. I only sold mine because of the well. It was superb to have though in the summer when our only means of cooling was an evaporative cooler. Once it got the electric motor going, it quickly idled down and could run for about 12 hours. I think it held 4 gallons of gas. As much as I hear folks talk about the inexpensive Coleman type generators which certainly have their place, the loudness is something I will gladly save and pay extra for to get a Honda inverter type.
/ Dewalt generators ?? #18
I purchased mine from lowes about 3 years ago. 5000 watt for $500.00. It has a B&S vanguard engine & it is a quiet running motor . might be more than $500.00 now . It has given very good service . Used for emergency power only.
2022 John Deere 6R 130 Tractor (A63111)
2022 John Deere 6R...
2012 Ford Explorer SUV (A61574)
2012 Ford Explorer...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A64279)
2021 CATERPILLAR...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
Here are some similar links:
