Deutz Front Seal Leak
   / Deutz Front Seal Leak #11
Hmmm. So welded the crack in the tub and feel I should have no new oil in the tub. But I do. My engine has been using oil I figured it was just wear but now I am thinking it might be the seal between the engine and the pumps.
Ugh.... If I have to do this I may just do a complete teardown of the machine, send in all the pumps and wheel motors for a rebuild and redo the timing belt as well.
Could be an expensive christmas. Or I just keep my eye on it and it costs me a quart every 20 hours or so.
Have you ever used the black light leak detector fluid that you can get at an auto parts store?
If not, I highly recommend it.
There's a few different kinds... engine oil, anti-freeze, etc... add the appropriate detector to your engine oil, run the machine for a while, then use a black light to find the leaks. I've used it on coolant leaks in my older cars/trucks several times. That's how I found a leaking water pump behind a cover that I couldn't see on one of our Impalas. Works best in the evening or a darkened garage. :thumbsup:
   / Deutz Front Seal Leak #13
I was thinking that, too.... ;)
Here's one of my 2001 PT425 for comparison....
484404d1476243062-deutz-front-seal-leak-pt425viewenginecompl-jpg
2006 John Deere 120C Hydraulic Excavator (A53421)
2006 John Deere...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
Year: 2005 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2005 Make...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55302)
BOSS MT 660 Fuel...
SCAN TO RECEIVE TEXT UPDATES (A52706)
SCAN TO RECEIVE...
2008 PETERBILT 367 FLAT TOP SLEEPER (INOPERABLE) (A55745)
2008 PETERBILT 367...
