Deutz Fahr Agrokid 55 starter problems
   / Deutz Fahr Agrokid 55 starter problems #1
gojicoach
Edmonton
Deutz-Fahr Agrokid 55
I have a 2 year old Agrokid 55 with only 100 hours on it.
The battery is fully charged, however, it will not start.
When I turn the key on nothing happens.
Can you adjust the switch on the clutch and how would I do it?
Any help would be appreciated.
   / Deutz Fahr Agrokid 55 starter problems #2
hi,
i have the same problem here, has anyone a solution?
thx
   / Deutz Fahr Agrokid 55 starter problems #3
Argokids, SAME Solaris, and Hurlimann Prince all share the same construction, and I can assume the same wiring scheme.
According to the wiring diagram, and consistent with my own Prince 435, both clutch pedal must be depressed fully, AND the PTO clutch must be disengaged.
The clutch pedal interlock switch is easily inspected as there is useful access to both sides of te foot well where it is mounted. If suspect, it is easy enough to jumper the terminals. (Normally open)
The PTO switch? I'm not sure how to access it. Perhaps exercising the PTO clutch control lever several times will loosen things up.
Good luck
Cal
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2025 Swict 66in Bucket Skid Steer Attachment (A51691)
2025 Swict 66in...
We do NOT accept credit cards as payment. (A50123)
We do NOT accept...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
2020 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2020 John Deere...
Electric Mobility Scooter (A51694)
Electric Mobility...
