Deutz F3M 1008 Engine Not Starting
/ Deutz F3M 1008 Engine Not Starting #1
Wilhelm Maike
NZ
Diesel
Hello All,
I have a Deutz F3M 1008 liquid cooled 3 cylinder diesel engine that won't fire! Not even with starting fluid.
Diesel is getting through because it smokes....
The glow plugs are working, because it billows smoke (while cranking) when they are on....
The fuel stop lever works, because when I push it (shut off position) while cranking, there is no smoke....
The timing 'seems' correct. I did try it (timing belt) in a few positions, but the piston will hit the valves, when it is wrong. (No, I didn't even try to crank it, when doing this test)
I have also installed a new starter motor.
I would greatly appreciate anyone's help and suggestions on this.
Thank you in advance.
Is there timing adjustment with 'pump duse' ?
/ Deutz F3M 1008 Engine Not Starting #4
If it won't pop on starting fluid, you don't have enough compression, or improper valve timing.
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
2004 DCT PUMP TRAILER (A58214)
2004 DCT PUMP...
SHOP BUILT TOOL TRAILER (A58214)
SHOP BUILT TOOL...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A61307)
Neckover GL24-2-7K...
