Deutz F3M 1008 Engine Not Starting
/ Deutz F3M 1008 Engine Not Starting #1
Wilhelm Maike
NZ
Diesel
Hello All,
I have a Deutz F3M 1008 liquid cooled 3 cylinder diesel engine that won't fire! Not even with starting fluid.
Diesel is getting through because it smokes....
The glow plugs are working, because it billows smoke (while cranking) when they are on....
The fuel stop lever works, because when I push it (shut off position) while cranking, there is no smoke....
The timing 'seems' correct. I did try it (timing belt) in a few positions, but the piston will hit the valves, when it is wrong. (No, I didn't even try to crank it, when doing this test)
I have also installed a new starter motor.
I would greatly appreciate anyone's help and suggestions on this.
Thank you in advance.
Is there timing adjustment with 'pump duse' ?
/ Deutz F3M 1008 Engine Not Starting #4
If it won't pop on starting fluid, you don't have enough compression, or improper valve timing.
Pallet Shelving (A60463)
Pallet Shelving...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
2017 Jeep Patriot 4x4 SUV (A59231)
2017 Jeep Patriot...
2010 Ford Crown Victoria Sedan (A59231)
2010 Ford Crown...
KJ K2223 23'x22' Metal Shed (A60463)
KJ K2223 23'x22'...
