Deutz engines
   / Deutz engines #1
Billblaster201000
Mahaffey
1011f in a 4635 skidloader
I recently bought a 4635 Gehl skid loader and discovered that the engine timing is with a belt. Anyone have experience with changing the timing belt? I've viewed turotials on line that make it seem pretty easy, with the right tools, pins.
   / Deutz engines #2
Its not bad, key is to keep everything from moving any till the belt is on and tensioned. I did my VW diesel Jetta years ago, wasnt bad and that was in a front wheel drive car. With better access it would have been even easier. Just use a high quality belt and not the cheapest you can find. Timing belts is one place I do not skimp on the part or part quality. Mike
   / Deutz engines #4
Done that 2X on my '03 Honda Odyssey 3.5l v-6. Takes longer to expose the belt than it does to change it and it drives the water pump also so I change that while I'm in there. Has 225,000 miles on it. Look for factory timing marks and highlight them or make your own...I'd be surprised if it lacks factory marks, arrows, etc..
   / Deutz engines
Change went well, timing is as it should be. Thanks for help.
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2014 Ram 1500 4x4...
Tiger Mower Hydraulic Tank Connection (A51691)
Tiger Mower...
GODWIN CD150 DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150 DRI...
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
UNUSED LANDHONOR BS-12-2500G BALE SPEAR (A54757)
UNUSED LANDHONOR...
2 pair -st205/75r15 radial trailer tires (A53421)
2 pair...
