Deutz Engine Fuel Issue
/ Deutz Engine Fuel Issue #1
cey146
Illinois
Ford 1620
I have a 1998 Ditch Witch 3700 Trencher/Backhoe. The engine is a Deutz F3L1011F. I used it a few days ago, parked it and left it idling while I did some hand digging. It died as if someone hit the kill switch. (so to speak) I restarted it, and it would only run for about 30 seconds, then repeat the same thing. Now, it won't start at all. It seems to be a fuel problem. Any and all help is appreciated.
/ Deutz Engine Fuel Issue #2
I am going to ask the obvious , but is there fuel in it ? You may be getting air in the system , or a filter is plugged . Have you got a boost pump from the tank to injector pump ?
There is about 3/8 of a tank of fuel. I have loosened the nuts on top of the injectors, and have nothing there. Took the fuel pump off, and it seemed to work by hand. I'm no mechanic, but can make repairs........with a little help from my friends!
/ Deutz Engine Fuel Issue #4
Could be trash in the fuel tank. Blow air back thru the fuel line in to the tank and see if that fixes it. I had a Deutz engine do this and this was the problem.
I replaced the fuel pump, and it started right up.
Thanks to all for the help!
/ Deutz Engine Fuel Issue #7
Nice machine...glad you got the issue resolved...
I have a 3610 with A322 BH...
Wish there were more D.W. enthusiasts here on TBN...
I have found info on these machines to be very well protected. Hard to get a drawing, diagram, parts list, or anything to help with repairs. This one has a problem with the gauges not working 1/2 of the time, it has to be a loose connection or poor ground somewhere.
/ Deutz Engine Fuel Issue #9
I was quoted a price for a service manual at around $80.00...but parts are not overly expensive...and readily available...They are very well built and are work horses...
Now searching again, for a wiring diagram. Only getting 8 volts to the fuel shut-off solenoid. The engine won't fire. When I put a 12 volt source to the solenoid, it fires right up. I need to know where the other end of the wire is terminated, so I can replace it. It gets lost in a wiring harness, and becomes untraceable.
/ Deutz Engine Fuel Issue #11
I wouldn't struggle with it too much, I'd get the old wire out of the way, and run a new wire to the ignition switch... lol
SR
After carefully tracing the wiring, I've found the issue to be in the neutral switch (footswitch), located at the backhoe operator's station. The limit switch's normally closed contacts were corroded, and stuck in the open position.
After cleaning with electrical contact cleaner, and replacing the ring lug terminals, the engine starts as it should. The footswitch allows the operator to move the machine forward or backward, with the backhoe bucket.
/ Deutz Engine Fuel Issue #13
Check your fuse block or your key switch. They usually are wired to accessory power so when the key is turned on, the solenoid engages the fuel rack.
Have another issue, which has been an intermittent problem for 3 years. Now, it is a steadily recurring trouble. Machine has about 1500 hours on it. Sometimes runs very rough, has zero power, and is unusable. Checking into it, we find it to only be running on two of the 3 cylinders, and after it gets warmed up, it may only hit on 1 cylinder. I've read many comments on several different forums. Most agree the Deutz to be a good engine, and often don't have problems with it, at so few of hours.
Having changed the fuel fiter, and examined the screen in the fuel pump, I'm at the end of my knowledge as to what to try next.
As always, help from you professionals is very much appreciated.
/ Deutz Engine Fuel Issue #15
I had one do things like that, I traced it to junk floating in the fuel, plugging the outlet from time to time.
I suppose a "suction" air leak in a fuel line some place would cause that too...
SR
/ Deutz Engine Fuel Issue #16
I simply put in a electric fuel pump & solved my problem. I replaced the factory fuel pump twice about every 50 hours. Havn't had a problem now 200 hours later. Use a low voluem pump, 4 - 7 pounds
/ Deutz Engine Fuel Issue #17
Fuel shut off solenoid needs replacing. If it kills with just the key and no pull off.
Skid Steer Blank U-Plate (A65640)
Skid Steer Blank...
2021 John Deere 5100E (A64126)
2021 John Deere...
2015 Kenworth T680 (A64127)
2015 Kenworth T680...
AR500 Coyote Target (A65640)
AR500 Coyote...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
2021 SANY SY26U EXCAVATOR (A63276)
2021 SANY SY26U...
