Deutz D30-06
/ Deutz D30-06 #1
Dahlonega, Ga USA
Long 360, John Deere 3005, Farmall Cub, Case IH495, Fordson Power Major
Good morning everyone! My name is Sumner
A little backstory: I have my grandfathers early 1970's Deutz D30-06 2cyl tractor. I am extremely fond of it as it was the tractor I would ride on as a child at his SC farm. After his passing my father inherited all tractors including the Deutz. After several years of the tractor sitting my father let me take ownership. Since then I have replace the bent and rusted hood with a nicer one, installed LED lights to night work, cleaned up the wiring harness, had it serviced by a Deutz Mechanic (no longer in business). It use to smoke horribly (i believe from the little use and never fully warming up) to now it smokes when cold but mostly clears up now since I run a Lucas oil additive for old engines and quality oil.
My concern is since I have had it (2 years) It has not been serviced; that was done right before I got it. Im not concerned about oil and hydraulic services but I am concerned about fuel filter. It is a horizontal orientation which I have no experience with. Has anyone here had any experience with a a F2L912 engine? If so I would be grateful on how to properly change and prime the fuel system. If there is any trick and tips.
I really love this machine and would love to pass it on to my son one day!
Thank you for any advice and opinions!
/ Deutz D30-06 #3
i can't answer directly to your question as others i'm sure will. just a compliment on your respect for a quality old school tractor and the generations it's served, & to serve. good work
/ Deutz D30-06 #4
They make 2 filters for that tractor, one is shorter than the other, both work.
Spin the old one off, and spin the new one on, there's a place to bleed the air out of it on the filter housing.
SR
/ Deutz D30-06 #5
Good luck with your restoration/maintenance of an old workhorse. I would order a spare fuel filter and maybe an engine oil filter too, etc. Always great to have for an emergency…
/ Deutz D30-06 #6
30-06 doesn't have a replicable oil filter, you pull the fine mesh screen and wash it with diesel, then put it back in.
Fuel filters aren't all that hard to get.
SR
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63688)
2023 Kubota L3560...
2006 TerraGator 8104 (A63688)
2006 TerraGator...
1000 GALLON POLY NURSE TANK (A64276)
1000 GALLON POLY...
2018 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A61572)
2018 Takeuchi...
2012 JLG G9-43A TELESCOPIC FORKLIFT (A64279)
2012 JLG G9-43A...
