Deutz Allis Hydraulic Issues
   / Deutz Allis Hydraulic Issues #1
Evelynburyfarm
Scottsville, VA.
Deutz Allis 6250
Hi, I have a Deutz Allis 6250 I have replaced the power steering motor, got everything hooked up and smoked the hydraulic pump. Got a new pump double checked everything to make sure it was hooked up correctly, started the thing up and nothing no steering, no loader, no hydraulics working at all turned the thing off before I burned up this hydraulic pump..........frustrated! I've been fooling with this thing for 6 months. Any ideas suggestions appreciated. Thanks, Jim
   / Deutz Allis Hydraulic Issues #2
Pull the pump one more time and reckeck shaft, gears or coupler. I wouldn't start until you are 100% sure the steering valve is hooked up right.
   / Deutz Allis Hydraulic Issues #3
For added protection, install a relief valve after the pump. That way, the pump will be protected for any mistakes you make downstream.
Have you check for a complete flow path?
Install a hyd gage so you can see where you have pressure and how much.
UNUSED RAYTREE RMDM70 - 70" DISC MULCHER (A54757)
UNUSED RAYTREE...
2016 Caterpillar 349FL Hydraulic Excavator (A55787)
2016 Caterpillar...
2012 TRAVIS 39FT DUMP TRAILER (A54607)
2012 TRAVIS 39FT...
2017 Nissan NV200 Cargo Van (A55788)
2017 Nissan NV200...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2021 Ford F-150...
2017 VOLVO VNL TANDEM AXLE SLEEPER (A54313)
2017 VOLVO VNL...
