deutz 40-6 hydraulics
/ deutz 40-6 hydraulics #1
merlet
salem ark
farmall model a
when in operation no leaks when i shut it down the hydraulic fluid comes out of the steering column. is their a filter that can cause this or check valve/? i have no data on this and know nothing about this system. any help thanks merle
/ deutz 40-6 hydraulics #2
There is a basket down in the hydraulic reservoir that will catch some trash, but the hydraulic filter is under the front of your seat...
It has a triangle shaped cap on top of it, held down by three screws. There's two types, early had a short filter, later models had a longer filter, the difference is a "riser block" that allows a longer filter to be used. To replace it, take the cap off and pull the filter out...
I don't think "it" has anything to do with your leak though. Perhaps you have a bad seal where it's leaking??
You can get a filter at 231-924-3438 ask for Peter... He may be able to help with your leak too?
SR
Clark GPX25 Propane Forklift (A64047)
Clark GPX25...
2013 FREIGHTLINER Cascadia (A63118)
2013 FREIGHTLINER...
2022 John Deere 5055E (A60462)
2022 John Deere...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
2005 Sterling Acterra Tender Truck (A63118)
2005 Sterling...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
