DeThatching?
/ DeThatching? #1
DannyD
Indiana
BX 23
I know this has been thru the ringer and I did a search for dethatcher on the forum search and got some good ideas and information. I have an acre, I need to dethatch it badly. I used my garden rake on a bit of it and got out more than I would have believed.
Will the ones at TSC do this also, does anyone have expereince with them or know any other units available. I dont mind spending a few extra bucks for a good one, and dont care it is pull or 3 pt, I just need to get this done.
Thanks in advance.
/ DeThatching? #2
Danny,
Don't know if you can find one in your area, but I use a pine straw rake to dethatch my pastures every couple of years. A pine straw rake has 1/4-inch spring steel tines set about 2 inches apart. It is not nearly as aggressive as a landscape rake.
I think that I paid about $150 for my 5-foot, 3-point hitch rake at the Leinbach factory outlet in Winston-Salem. It is really easy to mount - probably weighs only 60-70 pounds.
Good Luck.
/ DeThatching?
I will look into one, dont suppose you have some photos of one.
Found the website, but they dont list this item on it, mostly heavier stuff. I will email them about this
thanks
/ DeThatching? #4
Core Aerators can actually be better for your yard. You are mixing the thatch with the dirt to produce an organically rich environment. Won't look good for a week or two, but is well worth it it terms of labor and long term lawn health.
/ DeThatching? #6
Another option is a rotary broom - does a great job of dethatching.
/ DeThatching?
I have thought of this also. Right now would be good, since without rain in a month of Sundays, it looks bad anyway. Not sure what to do right now, $$$ will be a consideration. We also looked at this place tonite..........
2 acres, mostly front yard, but LARGE real fine garage......house is nice too!
/ DeThatching? #8
Danny,
I use a 200 some dollar CA that I bought when I had a lawn tractor. I have to put bricks on it (by design) to sink it. It works fine and I lend it out what seems like all the time to friends who have discovered this simple alternative to thatching.
Best of luck,
Buck
/ DeThatching?
Glad to find out that it worked for you. My only concern with them is this rock hard clay we have here. It is like bricks right now, I doubt that I could get it to cut. I do have some heavy blocks to put on it though.
/ DeThatching? #10
Wish I had advice about your rock hard clay situation. Any one out there with an opinion?
/ DeThatching? #11
I'll atempt an opinion. Earthworms eat thatch in good soil. You need earthworms.
How can you get earthworms? IMHO, by making your soil organically rich.
I'll shut up for a while...
/ DeThatching?
Here is the front yard.........goes down the line to the cedar on the left side and the last pole on the right. Since I would be doubling the size of the yard, should I not be able to double the tractor size, or at least implements.
The 'drive" is well over 300' and was installed by the county (it is what is left of a trail), but they do NOT do the snow removal. Guess one of those blades for the front of the bota would be needed.......... /forums/images/graemlins/grin.gif
/ DeThatching?
Now that would be good. I know that we have lots of birds eating something. What would make a core aerator perfect is about 3 days of rain, nice slow and constant. Then it would be perfect, and probably would be done as soon as the tractor could get on the ground.
/ DeThatching? #14
My view is that you might be suprised. Those spikes can penetrate!
I would talk to a nurseryman in your area about your clay situation. Not a lawn maintenence guy 'cause I am sure he'll have you dependent on chemicals.
There are a lot of very good books on agronomy that I would be glad to recommend if you send me a private message.
/ DeThatching? #15
I agree, but they are super expensive. I looked at a Sweepster, but it was more than $3,000. Of course, you can always rent one...
/ DeThatching? #16
I got a John Deere core aerator. It looks like little dog turds all over your yard after you run over it. Agri-Fab has a couple of less expensive aerators too. I just prefer the fit and finish of the JD.
/ DeThatching? #17
Attached is a pic of my "custom" front dethatcher. Simply bolted to the frame of my 54" front blade. The blade frame "quick-tatches" to the front hydraulics:
/ DeThatching? #18
A little more detail in case you are interested in the attachment hitch setup:
/ DeThatching? #19
My Turfco TM42 Aerator:
/ DeThatching?
You werent the lucky lotto winner where you? I know where you can put that aerator to work for a day or two..........hey free seat time, cant beat that!
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2015 Isuzu NPR HD Porta John Recovery & Cleaning Truck (A62613)
2015 Isuzu NPR HD...
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
2018 Case 580N EP 4x4 Loader Backhoe (A64553)
2018 Case 580N EP...
HYDRAULIC AUXILIARY TRANSMISSION (A65643)
HYDRAULIC...
Case IH 200 50' Field Cultivator (A66285)
Case IH 200 50'...
