Detachable FEL hydraulics help
/ Detachable FEL hydraulics help #1
dboacres
Bronze Member
Central Calif hills & Glide, Or
Ford 2110, 1920, 1710
I have Ford 770B and 7108 detachable loaders. The 770B manual says to turn the spool on the relief valve/diverter valve, to take the pressure off the hydraulic pump, after removing loader. Both loader remotes are tractor mounted. (stay on tractor when loader is removed) Common sense tells me that changing the spool is not needed unless the loader remote control valve come off the tractor and are mounted onthe loader. I just want to be correct and not hurt the pump.
/ Detachable FEL hydraulics help #2
That doesn't seem to make a lot of sense...
Anyway, I just move the joystick around quite a bit to relieve pressure before unhooking the FEL hoses.
Works for me...
New/Unused Landhonor Adjustable Gantry Crane (A61166)
New/Unused...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
New/Unused Quick Attach Flail Mower (A61166)
New/Unused Quick...
2019 GENIE S-60XC TELESCOPIC BOOM LIFT (A62129)
2019 GENIE S-60XC...
2018 John Deere 323E (A62177)
2018 John Deere...
Baby Goat Decorative Statue (A61569)
Baby Goat...
