Snow Equipment Owning/Operating designing a mechanical means to turn a snow blower chute
   / designing a mechanical means to turn a snow blower chute #1
tommyboy1
north branch, michigan
ford 4600
hello all,
I am trying to modify a three point rear mounted snowblower so that i can use hydraulic or electric power to rotate the chute instead of moving it manually. Does anyone have pictures of this type of mechanism on on a commercially built snow blower or have ideas about something they may have created themselves.
   / designing a mechanical means to turn a snow blower chute #2
Here's my homemade hydraulic setup. I used a cylinder that I had laying around doing nothing. Works great!
   / designing a mechanical means to turn a snow blower chute #4
The left picture is one I made - the cable rides on a curved piece very close to the chute. The cable wraps around the chute with the ends tied off. Same idea as Farm King (Allied, Buhler) - right 2 pics. Cable length stays constant through the travel.
Thanks for the info. As someone who has done a lot of metalworking, you did a really nice job! good pictures also.
thanks for all the good info. I finally know where to go now for this type of stuff. thanks again!
   / designing a mechanical means to turn a snow blower chute #7
I used a cheap HF winch. Rope was only used for testing.
   / designing a mechanical means to turn a snow blower chute #8
ZIK
I see a large caster under your blower. Are there 2?
Interested to know how it (they) serve (s).
And nice winch install. All the torque U need as well as correct speed.(I also used winch)
   / designing a mechanical means to turn a snow blower chute #9
Yes there are two swivel casters bolted on (temp setup) to keep the blower from digging into my gravel driveway. So far it's works pretty well except we haven't had enough snow in the past 2 winters to really test it out much.
2011 GLOBAL 130BBL VAC TRAILER (A52472)
2011 GLOBAL 130BBL...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2017 TOYOTA TUNDRA (A52472)
2017 TOYOTA TUNDRA...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
