depth control 60"mmm
/ depth control 60"mmm #1
ACMIKE
Harrington, De.
Kubota BX 2200
depth control 60\"mmm
BX 2200 with a 60" mmm while mowing, it goes from 3" to 1.5" anti-scalp wheels are really taking a beating. Maybe going to fast /forums/images/graemlins/confused.gif
/ depth control 60"mmm #2
Re: depth control 60\"mmm
Not sure I understand what you are asking here, are you saying the deck raises and lowers while cutting?
How even (or uneven) is the area you are
mowing?
Sorry, I mean the cutting height control dial that I set for 3" moves to 1.5 on its own while mowing.
/ depth control 60"mmm #4
acmike:
Are you setting the height gauge when the mower is fully raised? If so it should not drop......maybe the linkage is disconnected.
Have you locked the 3ph in the full upright position?
/ depth control 60"mmm #5
I've had this happen many times as well. My yard is pretty bumpy, and if I get going too fast the deck gets bouncing around enough to cause the height control dial to change. What I do now, is tighten the dial that controls how fast the deck/3point to drop. This way, if things start bouncing around too much and the height control dial changes, the deck won't drop.
Also, make sure you have the anti-scalp rollers set high enough. You might want to raise them one more notch than your current setting.
/ depth control 60"mmm #6
Do you mow in rabbit or turtle?
My deck used to slam all over the place, I just slowed down a bit. Another option would be to dedicate some time to smoothing out the yard. But I'm too lazy (so far) for that.
2014 Ford Escape SUV (A61574)
2014 Ford Escape...
UNUSED WOLVERINE 3PT QUICK HITCH RECEIVER (A64281)
UNUSED WOLVERINE...
Rake Master CR-72G (A64119)
Rake Master CR-72G...
FORD 1320 TRACTOR (A64280)
FORD 1320 TRACTOR...
2016 CHEVROLET EXPRESS PASSENGER VAN (A59912)
2016 CHEVROLET...
2019 CAT 305E2 CR Mini Excavator (A62613)
2019 CAT 305E2 CR...
