Dennis E. Colvin
/ Dennis E. Colvin #1
brdnis
Forrest City, Arkansas
1986 Ford 1510
I am looking for engine parts for a 1510 Ford tractor. I am needing 3 pistons, rings, inserts, Mains, and gasket kit. With a caliper the cylinders measure 3.16 inches and the old pistons measure 3.14. The block is put back to standard, (already done) and I am needing standard bearings.
If you could help me with this task, I would deeply appreciate it. I don't want to spend enough on engine parts to buy another tractor, and the parts can be aftermarket if you have them. I just want to put it back together as inexpensive as possible.
Thanks in advance for any and all the help you can give.
Dennis E. Colvin
/ Dennis E. Colvin #2
Dennis E. Colvin
Welcome to TBN Dennis. Your best bet is to repost this in the Ford forum so Sound Guy or some one see's it, Good Luck.
207279 (A52708)
207279 (A52708)
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
2012 Ram 1500 Crew Cab Pickup Truck (A61568)
2012 Ram 1500 Crew...
2010 Case 580N (A60462)
2010 Case 580N...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A62131)
UNUSED RAYTREE...
2025 DORSEY 48' STEEL FLATBED (A59909)
2025 DORSEY 48'...
