demolition hammer
   / demolition hammer #1
swick1
Platinum Member
WV
John Deere 1026R
Check out this patent: Demolition hammer
Sheet 4/5 shows a model that should be easy for any of us to build and it would sure save my back! I contacted the company about buying one for a 260 backhoe and they didn't have anything that would fit. I ordered the information video which showed that it would work pretty well. If I modified the hammer to have a conical shape at the end it would probably work even better. I think this will be another project for me to do this winter.
Full Patent: Demolition hammer - Lindsey, Edgar F.
Website: Universal Impact Technologies - Serious Equipment for Serious Work
   / demolition hammer #2
Ive actually run the Universal Impact Technology Powersledge before a good bit. I worked for a company that had some that we used for bridge decking and slabs and other concrete. They work pretty good, We had one that attached to a Bobcat QT. It was a bit awkward on the foot controls. We had an older on that had a hinged pole with a hammer on the end with a cylinder that was attached with a cable. It would pull it up and tilt the QC back and then run the cylinder back out. Then tilt it forward and let it fal lto te ground It worked well on the loader.
2012 MACK CHU613 (A50854)
2012 MACK CHU613...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2001 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2001 Big Tex 10PI...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A51039)
Morooka MST 660VD...
48in Forks Loader Attachment (A49346)
48in Forks Loader...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
