Demolishing concrete culvert
   / Demolishing concrete culvert #1
herbenus
Magnolia, TX
99 JD4200 4WD Collarshift
I have three 4-foot diameter by about 6 or 8 feet long cement culverts that were on my place when I bought it. Any suggestions on how to demolish? I can't move them except maybe to just nudge. I tried a masonry blade on a circular saw to slit into pieces, but first cut was only 1/4 inch deep (to scribe) and it took some time. My thinking was to cut culverts into 3 segments and use to line the bottom of creek where it's eroding. Maybe rent a bigger saw? I tried ramming down with a heavy pipe tied to fel. It just laughed and shook me a new one. If I broke it up I could use pieces for erosion in creek. I thought I might make a battering ram or ball, but even if it worked, fel is not really good for swinging heavy weights around. I could rent a jack hammer. I'm in the market for a compressor but I'm not sure a small compressor would suffice. It would have to be 110V to plug in near culvert, or get 300 feet of hose with the inherent pressure drop. Wall thickness is about 4 inches with two pieces of wire reinforcement. And must be made of some high strength concrete.
   / Demolishing concrete culvert #2
My first thought was a jackhammer. You can cut it into the size chunks you want.
   / Demolishing concrete culvert #3
Rent a jackhammer. If you've got 110v nearby you can rent a full sized electric jackhammer. Skip the handheld models for that job. If you go air you'll have to rent a large engine driven compressor as well. The homeowner/hobbyist compressors don't put out the flow for a jackhammer.
Sounds like a fun project... not /forums/images/graemlins/smile.gif
   / Demolishing concrete culvert #4
Do they make these things with re-bar in them?
Might be hard to bust it up if they do.
   / Demolishing concrete culvert #5
Hi,
Mabye you could sell them on ebay...
   / Demolishing concrete culvert #6
I would think you could sell them to someone who wants to put in a culvert or make a bridge.
Otherwise, I would use my FEL and dig a hole and bury them. Good tractor time and they will be there if you ever want them later. Underground storage at no cost, and no "breakerage "fees. /forums/images/graemlins/grin.gif
   / Demolishing concrete culvert #7
Try this:
Find a promissing, round rock that is as big as you feel comfortable lifting with the FEL. Position the FEL/Rock as high up as you feel ok with, and let the rock roll out of the FEL and hit the pipe. Repeat till all broke up.
I don't know for sure if it'll work, but I can tell you from experience that it works 'accidentally' /forums/images/graemlins/frown.gif
   / Demolishing concrete culvert #8
And I'd be careful that when raising the FEL that the big rock rolls out the front of, and not the back of, the bucket. It will make a disturbing mess out of the nice finish on the hood of your tractor.
   / Demolishing concrete culvert #9
So would the ricochet when the rock bounced off to the rear of the culvert towards the hood
   / Demolishing concrete culvert #10
Sorry - I just posted a really dumb idea /forums/images/graemlins/blush.gif...
Jackhammer sounds like the best route. The 110 plug in types work pretty well and should to it for you, without the danger of dropping large objects.
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
2014 Ford Explorer Sport AWD SUV (A51694)
2014 Ford Explorer...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A53472)
UNVERFERTH 330 -...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
TUBELINE TL50LSV LOT IDENTIFIER 107 (A53084)
TUBELINE TL50LSV...
2021 John Deere RD40F Draper Head (A53342)
2021 John Deere...
