Demolishing concrete culvert
   / Demolishing concrete culvert #1
herbenus
Magnolia, TX
99 JD4200 4WD Collarshift
I have three 4-foot diameter by about 6 or 8 feet long cement culverts that were on my place when I bought it. Any suggestions on how to demolish? I can't move them except maybe to just nudge. I tried a masonry blade on a circular saw to slit into pieces, but first cut was only 1/4 inch deep (to scribe) and it took some time. My thinking was to cut culverts into 3 segments and use to line the bottom of creek where it's eroding. Maybe rent a bigger saw? I tried ramming down with a heavy pipe tied to fel. It just laughed and shook me a new one. If I broke it up I could use pieces for erosion in creek. I thought I might make a battering ram or ball, but even if it worked, fel is not really good for swinging heavy weights around. I could rent a jack hammer. I'm in the market for a compressor but I'm not sure a small compressor would suffice. It would have to be 110V to plug in near culvert, or get 300 feet of hose with the inherent pressure drop. Wall thickness is about 4 inches with two pieces of wire reinforcement. And must be made of some high strength concrete.
   / Demolishing concrete culvert #2
My first thought was a jackhammer. You can cut it into the size chunks you want.
   / Demolishing concrete culvert #3
Rent a jackhammer. If you've got 110v nearby you can rent a full sized electric jackhammer. Skip the handheld models for that job. If you go air you'll have to rent a large engine driven compressor as well. The homeowner/hobbyist compressors don't put out the flow for a jackhammer.
Sounds like a fun project... not /forums/images/graemlins/smile.gif
   / Demolishing concrete culvert #4
Do they make these things with re-bar in them?
Might be hard to bust it up if they do.
   / Demolishing concrete culvert #5
Hi,
Mabye you could sell them on ebay...
   / Demolishing concrete culvert #6
I would think you could sell them to someone who wants to put in a culvert or make a bridge.
Otherwise, I would use my FEL and dig a hole and bury them. Good tractor time and they will be there if you ever want them later. Underground storage at no cost, and no "breakerage "fees. /forums/images/graemlins/grin.gif
   / Demolishing concrete culvert #7
Try this:
Find a promissing, round rock that is as big as you feel comfortable lifting with the FEL. Position the FEL/Rock as high up as you feel ok with, and let the rock roll out of the FEL and hit the pipe. Repeat till all broke up.
I don't know for sure if it'll work, but I can tell you from experience that it works 'accidentally' /forums/images/graemlins/frown.gif
   / Demolishing concrete culvert #8
And I'd be careful that when raising the FEL that the big rock rolls out the front of, and not the back of, the bucket. It will make a disturbing mess out of the nice finish on the hood of your tractor.
   / Demolishing concrete culvert #9
So would the ricochet when the rock bounced off to the rear of the culvert towards the hood
   / Demolishing concrete culvert #10
Sorry - I just posted a really dumb idea /forums/images/graemlins/blush.gif...
Jackhammer sounds like the best route. The 110 plug in types work pretty well and should to it for you, without the danger of dropping large objects.
2003 Lincoln LS (A50324)
2003 Lincoln LS...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A53472)
Kubota BX2680...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
BESTWAY AG VSK35 LOT IDENTIFIER 114 (A53084)
BESTWAY AG VSK35...
20ft x 20ft Steel Carport (A51573)
20ft x 20ft Steel...
John Deere 114in 5-Deck Fairway Mower (A51691)
John Deere 114in...
