Delta Car Hauler
   / Delta Car Hauler #1
yooperdave
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
I can get a new 9,990# 18' delta car hauler for $3,000 with choice of ramps.
Does delta make a good trailer? Brakes are on both axles. Tires are new.
Is this a good deal?
Are flip up ramps better then pull out ramps or vice-versa?
I need to make a decision soon.
TIA
Yooper Dave
   / Delta Car Hauler #2
Never heard of Delta. I can beat that price by $1000 but thats hear and I have learned on this site that trailer prices vary greatly by region.
I like slide in ramps. Fold up ramps will block you from hauling something slightly larger than the trailer like a long car, 20' lumber, tractor with FEL and a BH on back. Usually the tail wheel hangs off by a foot or so.
Also the fold up ramps are a major aero drag. Many will not believe me but a mesh gate has more drag than a solid piece of steel the same size. It has to do with surface area and Parasite Drag. Trust me, I have a Aero Space Degree.
If I were you I would load up the wife and take a weekend trip to Southern MO. You could make the trip a weekend get away and save a ton.
Check them out. This is one I have bought from. They do not list a 18' car hauler but they can make you anything you want. Heck they have a tilt deck for under $3,000
http://www.jerryjamestrailersinc.com/
Chris
   / Delta Car Hauler
Welcome to Jerry James Trailers
Chris
It's amazing what a few hundred miles can do to the price.
I have not seen a new 18', 10k trailer for less than $3,000 up here - regardless of manufacturer.
Finding a nice used trailer is near impossible - people must like to hang onto their trailers.
Yooper Dave
   / Delta Car Hauler #4
Yes, I looked it up and it would be a good drive. I forgot how far up Green Bay is.
Anyway, Jerry James trailers are not the prettiest but they are well built and a good value. I have had 2 with zero issues. My current one is a bigger version of a landscape trailer. Its 18' long by 82" wide. Bought it new in 2004 for $860 and installed my own brakes for under $200. It has 5' ramps and I also mounted a winch to the front. I also welded on 8 D rings and just put new tires on it this spring.
It has hauled tons of stuff including building materials, a hot tub, my tractor, full size trucks, a Suburban, and some 15 or more broken down or junk cars. Here is a picture of it behind the 2004 F250 4x4 PSD during a deck build in 2004.
Most of that lumber is 20'. That is why I did not want a fold up gate or ramps.
Chris
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A53472)
2012 KINZE FLAT...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2013 Dodge Charger Sedan (A52377)
2013 Dodge Charger...
2012 BMW 328i Coupe (A51694)
2012 BMW 328i...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
