deleted
/ deleted #21
OK,
My 4110 manual states
50 Hrs
Change Engine oil & filter
Change Transmission oil & filter
Other things
every 200 hrs
Change engine oil and filter
Change transmission oil & filter
Other things
For hydo transmissions, transmission fluid means the hydro fluid, I guess. If you mant more deatil, the manual is online.
Cliff
/ deleted #22
Thanks bigpete for your response. I looked at the 4300 owners manual this weekend and it says change at 500 hours. I just posted a new question about all of this in the forum.
/ deleted #23
I changed my transmission/hydraulic fluid on my 4010 at 50 hours and am glad I did. It had some thin break in fluid I guess of some sort in it and I noticed the transmission had began to whine quite a bit when nearing 50 hrs. The 4010 had an internal filter that has to be replaced and when I changed it I took one of the magnets from inside it and ran it around the bottom of the transmission. You would not believe the metal shavings I got out of it! After I changed it it quit whining exessively and the hydraulics worked smoother.
Pallet of Two Pivot Wheels & Tires (A62177)
Pallet of Two...
UNUSED WOLVERINE HYD MINI AUGER (A64281)
UNUSED WOLVERINE...
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
2013 Kubota BX2370 54in 4x4 Compact Utility Tractor Mower with 48in Rotary Brush Cutter (A61572)
2013 Kubota BX2370...
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
UNUSED WOLVERINE TREE DIGGER (A64281)
UNUSED WOLVERINE...
