deleted
/ deleted #2
Welcome to TBN! A couple of thoughts...
Did you find out what the cash price would be? You often give up a couple thousand in discounts when financing with 0% interest.
How much is the quick attach loader? I would not buy a tractor without one. I have a bucket, snow plow, forks and plan to get a grapple. Changing implements is super easy.
You are looking at the smallest of the tractors. I would consider getting a little bigger. You won't regret having more HP, more weight, larger tractor (assuming you stay in the small category and don't get a 100hp tractor!) you will be able to do more work faster the bigger tractor you go.
/ deleted #3
Bigger is usually better, but only you can know whether your finances stretch to it.
The BX1880 can drive itself fine with 18HP, and can drive the 54 inch mower fine. But you have some PTO things in your list (tiller, brush hog) and 18hp will limit what you can drive. Most people would get the 2380, although not that many can articulate why. :)
The quick attach is good if you change implements. If you're like me and never take the bucket off, then it's just additional weight that lowers your effective lift capacity.
The Massey would be the wrong colour. :) I wouldn't personally buy a Massey, I think Kubotas are a better tractor. But it's all horses for courses really - only you can decide on that. More HP might be useful - the 1880 is a bit low.
/ deleted #4
Kubota is the only one around that doesn't jack up the price when offering the 0% financing. Cash price is the same, surprisingly. If my math is right, what they're offering is more than 10% off MSRP.
However, it is less tractor.
I'm trying to avoid having 1 machine for the lawn and 1 machine for the field/woods and thought the 1880 would be a good way to bridge the gap but am just not sure.
I don't know if I'll be changing implements or not. I know I won't be buying any additional for some time unless I can find some inexpensive 3pt implements like a small brush hog and tiller. I think the difference on the Quick Attach Lever bucket is a $400 increase.
Is there a physical size difference on the bx2380 or just engine size?
The 18 is a little shorter.
I use my 1860 with a 48 inch bush hog and woods backhoe no problem. Don't know on the tiller. If I could do it again I would have got a bx25 with backhoe and all up front just for ease. I haven't come up short on power, I have come up short on weight/traction.
How much extra would a 23 be it wouldnt hurt.
I upgraded to the bigger bx25 r4 wheels and tires later.
Definitely get qa bucket. The qa forks will be way better than the kind you put on the bucket. You need forks for logs and such. Can also unload stuff from your truck or delivery truck, the uses are endless.
If you ever want a backhoe or anything else, get it now.
I paid mine off quick, and spent just as much in upgrades later. Could have just got it all up front and paid the note longer. 6 one way half dozen the other. I just hate having debt so I did it the poor man's way buying a little at a time.
/ deleted #5
The 23 seems to be the sweet spot, but it's really only power that's different - there's a better seat and a tilt steering wheel I think, maybe a couple of other comfort things that probably don't matter for a lot of people. I think there's a consensus that the 26 is the "more power" option, the 18 is the "can't stretch that extra couple grand" option, and the 23 is what most people have. If I got a 23 I'd get a 60 inch mower too - it's materially more mower.
Ultimately you buy what you can afford - if you can't afford a 23 then you buy an 18.
On one machine to do everything, the B2301/2601 mows fine too, much bigger than that and no, you wouldn't really have a single machine that does it all.
If you're never going to buy front forks, a front grapple or a front snowblower, then quick attach has no purpose, don't spend on it. 3ph attachments are different again, so the quick attach isn't going to help there. I personally have rear forks not front ones, there are some limitations with rear forks, but it means I can put a pallet on them and they double as a transport tray or a counter weight for the FEL - so personally they work well. Main issue is I can't lift very high - so I need a chain around the bucket or I need a loading ramp if I need to lift higher than the 3ph will lift.
/ deleted #6
I couldn't face a new tractor, so I bought a beat up old 2350. It's good, but it's beat up. Next year I'm trading it on a brand new one, once our local 80 series prices have dropped a bit (no deals on them yet in NZ). The 2350 has no tilt wheel. The missus knows no different and has never complained.
Personally I'd stretch to the 23, and that'd be enough to do what you describe. I'd worry with the 18 you'd always wish you had a bit more. Sure, you'll always want a bit more, but it's easier to tell yourself "that's a whole new model of tractor" than "I didn't spend 10% more to get enough power.
I know people say the Kubota finance doesn't impact price (i.e. there's no discount for cash) but that really makes no sense, so I'd be asking carefully what the dealer would really give you if you had cash. i.e. could I have a 23 for the same price cash?
/ deleted #7
Thanks all,
The 23 is close to ~$2k more. Another dealer said I'd have to pick up $1600 worth of Kubota Insurance for 84 months but the local dealer hasn't said that yet, so I'm checking with my Allstate agent.
No need at all for a backhoe, and when we dig our basement/addition in the future it would be too small for that anyhow.
Probably wouldn't get a grapple-- I'll either be clear cutting brush or reducing & hauling out small logs. So I'd save myself the $$ on the 3rd Function as well. The tilt wheel on the 23 might be nice since it won't just be me mowing with it.
I guess it boils down to whether I want to get a 1880 and do everything with it, or get a new mower and still need to find a (used) tractor-- possibly a larger, older 2wd.
Never bought anything brand new before machine-wise (car/truck/mower) so a new tractor would be a big step. I can afford it... but do I want to? I tend to cheap out... heh.
2k is alot to a tightwaud like me. That's why I got a 1860.
I had to bring proof of home owners covering the tractor to opt out of Kubota insurance.
The dealers probably only get push back on insurance and accessories from the cheap *** 18xx buyers!
I was afraid to buy used, after being an equipment mechanic at a utility. Was afraid of what someone would have done to a small tractor with a hst transmission before I got it from them. (Use it like a d9 dozer for 2 years, go buy a d9 and sell the abused turd after putting the wrong fluid in the trans and not changing the filters)
/ deleted #8
Your out the door is around 500-1000 more than I paid 6 yrs ago, sounds right everything goes up in price.
/ deleted #9
The 23 will probably hold resale better or be easier to re sell later since its more popular. I
/ deleted #10
I bought my first SCUT last spring. I am in a similar position to you and think a BX will be a 1 machine that will do what you need. A dedicated mowing machine like a zero turn or a fancy garden tractor is a better mower (the turning radius of a SCUT is not great), but a SCUT can mow at pretty high speed and with a 5 foot deck you need an expensive mower to compare. All the other tasks you list will be fine on your size property. I can't speak to how much more you would like the different BX models.
We have no regret on buying a SCUT instead of two machines, it is a real workhorse but not too big for cutting a decent lawn. Without it we would be way less efficient in a wide variety of land maintenance and improvement tasks.
/ deleted #11
I've owned most all sizes of the BXs and Bs and a few Ls. First off the dealer gets no more or less money if you pay cash or finance. Most new machines belong to Kubota and dealers sell them and get their money at the end. Used machines are owned by the dealers.
I've owned a BX1500 which was/is the best BX for mowing and the most stable on hillsides. Sn in law has one for sale now with MMM, no fel, with 730 hours for around $6000 so you'll understand used pricing. My neighbor had a BX1800 MMM that climbed his hillside like a billy goat and never lacked mowing power. My niece has BX1870 MMM and uses their 60" Landpride tiller on it. I use a 48" Landpride tiller on my BX2370 so no problem with tillers. One person here said they used a Bush hog/rotary mower on their BX1800 and if they hadn't posted I'd have told you to forget rotary mowing with about any BX due to weight and power but mostly weight. A cheap rotary mower which will be light weight is useless after a few times using it or junk.
Kubota is currently advertising the BX1880 MMM for $99 a month for 84 months with zero down and 0% so you need to figure out how much for the FEL to determine fair price.
0% at Kubota can be a true 0%, sometimes. Sometimes there is no reduction in price with cash or credit and remember this is all up to Kubota and not the dealer. Sometimes Kubota offers a rebate (discount) if one pays cash which the dealer is informed. It was $700 a few years ago on the BX23xx but it comes and goes at Kubotas whim. I doubt there is any discount or rebate now on the BX1880 MMM since Kubota is pushing it on TV (VS JDs $100 a month one without mowing deck) and Barlows has a Kubota slick flyer on his counter promoting the BX1880 MMM for $99 month 0 down 0% 84 months and the B for $129 a month.
As someone has mentioned about traction. With most Kubotas in the compact and sub compact size they run out of traction before they run out of power. I personally has a choice last year between a BX1880 or the BX2370 MMM and I chose the BX2370-1 MMM but Kubota was not running their national sale with more competitive pricing on the BX1880 MMM. I rec'd the 60 months 0% and zero down so I pay about $30 more for 24 less months.
UNUSED JCT 84" HYD ROCK GRAPPLE BKT (A62131)
UNUSED JCT 84" HYD...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
2017 Dodge Grand Caravan Van (A61569)
2017 Dodge Grand...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
2020 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61568)
2020 Globe Trailer...
