Delco Voltage Reg. adjustments?????
   / Delco Voltage Reg. adjustments????? #1
BobG_in_VA
Veteran Member
Central VA, USA
Mahindra 6000 MWFD, 2 1950's Farmalls, 1974 Farmall 140, 1967 Mf 135Delux
Unit: '67 Mdl 135 Continental Gas....12volt Delco generator and Volt. Regulator....both are original....Background: I've adjusted the voltage on the regulator at least 10 times...re-start and check voltage; its either 13 or so,, so I increase...it then jumps up to 14.8 to almost 15volts...I've been trying to hit that nirvana of 14.4volts, but it has so far escaped me...Question: Any suggestions out there?? BobG in VA
   / Delco Voltage Reg. adjustments????? #2
Been a LONG TIME since I adjusted a voltage regulator on a generator/starter setup... But 13.8 volts is not bad if you can get it ' in the area ' of that... Probably your big problem is trying to set something low tech like that with a digital meter... Good luck... :)
   / Delco Voltage Reg. adjustments????? #3
   / Delco Voltage Reg. adjustments????? #4
JerryK
Thanks for the link on how to adjsut the regualtor. I am hoping that is my problem. currently i have no spark on my MH50.
Since someone else has chimed in...I got my regulator "regulated" a while ago...just forgot to come back and report..the battery is new, so it had nothing to do with how good or bad it was/is...since I'm not running anything else electrical with the tractor, I've found that 13.4 or so does just fine to keep the battery where it needs to be... Regarding no spark on your 50, the regulator won't have anything to do with that the coil, then go to the distributor...I've found that "new" condensors can be bad out of the box. Check your connections from your starter switch as well.. try and run continuity on everything you can...BobG in VA
2015 Top Hat T/A 20 ft. Gooseneck Trailer (A53117)
2015 Top Hat T/A...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
707A (A51692)
707A (A51692)
2015 Kaeser M114 100psi Towable Air Compressor (A51691)
2015 Kaeser M114...
2010 Chevrolet Impala Sedan (A51694)
2010 Chevrolet...
