Delayed reaction
   / Delayed reaction #1
s78wingrider
Hardy Co. WV
Mahindra 3215 gear
When using my hoe yesterday, on almost or all controls I was getting a delayed response, called the dealer and they said may need to change hyd filter. Know I need to and will but why was my FEL working fine if thats the problem? Thanks for any input! Aaron
   / Delayed reaction #2
They are SALES people
Post more detailed info about tractor and back hoe....
How is the hoe plumbing related to the FEL plumbing?
   / Delayed reaction #3
Check the fluid, see if it is foamy and/or milky looking. I suspect either a return/suction side leak or water in the fluid.
Few more details may help also, is this on a tractor? If so, then is it powered from the tractor or have it's own separate system (like a PTO pump)?
   / Delayed reaction
3215 mahindra, 3710 hoe, FEL?, both from L&M, plumbed from tractor, same location
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2025 IR UNUSED Ripper (A53117)
2025 IR UNUSED...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A51692)
2005 Toyota Tundra...
1265 (A50490)
1265 (A50490)
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
JOHN DEERE 9650 COMBINE (A51247)
JOHN DEERE 9650...
