Dehumidifier - Error code E6, Midea "Cube"
   / Dehumidifier - Error code E6, Midea "Cube" #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
About a year and a month ago I bought a Midea "Cube" 50 Pint Dehumidifier in Virginia for use in the basement of our Mississippi home where the humidity gets high in the summer. Hooked it up, ran it for about a week in Virginia as a test, worked well, reboxed it. Expected to bring it down to Ms, but life got in the way. Nice little dehumidifier, has a pump etc. and very portable.
Finally got it down here, hooked it up and it immediately threw an E6 error code which indicated a problem reading temperature. And wouldn't even power up fully
Looking online it was probably either an open or short circuit of room evaporator temperature sensor or a problem with the circuit board. So either replace the sensor or the circuit board.
I didn't want that cost ($$$) and the Midea "help line" was of no use (out of warranty by a month).
So I started playing with the buttons and found if I set it for NO BUCKET mode it would power on fully and work..
It seemed to work overnight and removed about a gallon of water.
   / Dehumidifier - Error code E6, Midea "Cube" #2
None of the dehumidifiers I have purchased in the last 12 years seem to last more than 2-3 years.
   / Dehumidifier - Error code E6, Midea "Cube" #3
We have a whole house dehumidifier. AprilAir 96 pint tied in the HVAC system. It lasted 12 years and had a leak in the coolant. Replaced myself.
By keeping the house dry, the AC can be set at 75 deg and feel great.
20 Gallon Air Compressor (A50860)
20 Gallon Air...
2014 Nissan Quest SL Van (A48082)
2014 Nissan Quest...
UNUSED 7/10 in. Twisted Manila Rope (A50860)
UNUSED 7/10 in...
2015 Ford Fusion S Sedan (A48082)
2015 Ford Fusion S...
2022 John Deere S780 Combine (A50657)
2022 John Deere...
Harrow Drag (A50860)
