Grading Definitive MMM blade height adjustment?
   / Definitive MMM blade height adjustment? #1
ADin
Indiana
JD2305, 1948 B.F. Avery Model V
I've seen a variety of posts here indicating that the front to back blade height adjustment should be biased either higher or lower by a 1/4in front to rear, both with arguments on grass cut quality and improving airflow, etc. My mower manual 62C on JD2305 only indicates that front to rear should be within 1/8in.
Is there an "ideal" blade adjustment regarding front to rear blade height? Also, assuming the ideal is perfectly level as the manual would imply then if one *must* introduce some error, say 1/8in, then should the 1/8in error be biased toward front or rear. Said another way, is error in one of the directions tolerated better than that other?
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
UNUSED AGT SKID STEER QUICK ATTACH SEEDERDRILL (A51244)
UNUSED AGT SKID...
2019 CATERPILLAR 289D SKID STEER (A51242)
2019 CATERPILLAR...
2015 CATERPILLAR 303.5E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
Diesel Forklift (A51691)
Diesel Forklift...
(5) Rolls of Barb Wire (A50515)
(5) Rolls of Barb...
