deere JD302 starter problem
/ deere JD302 starter problem #1
Doola
St. George, Utah
JD302-a
Greetings, I only get solenoid clicking when I try and start my tractor. I have replaced the two batteries and they are fully charged.
Is there anything else in the system that could cause the problem?? (other than the starter)
If the starter needs to be replaced, where is the best place to buy one. thanks,
/ deere JD302 starter problem #2
Assuming that starter & solenoid are good. If battery ground cable hasn't been relocated from battery box to engine block that should be performed at this time. If this doesn't help you could install this:RE42993 STARTER MOTOR KIT
Fuel Barrel on Stand (A65640)
Fuel Barrel on...
Red Oak Boards (A65640)
Red Oak Boards...
3 Point Hitch Cultivator (A65579)
3 Point Hitch...
2014 Tennant ATLV 4300 All-Terrain Litter Vacuum (A64553)
2014 Tennant ATLV...
2022 EZ-GO ELITE...
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59911)
1985 GREAT DANE...
