Deere Front Blade
/ Deere Front Blade #11
zman, I love your design. I think that design may end up on my tractor in another year or 2.
/ Deere Front Blade #12
Gunmakers set-up looks top notch, as well. Great "action" pic!
Northstar, reagrding your issue with frame mounting and stresses:
What I have learned reading and by observation is that the larger the blade, and the more work it is doing, And the stronger the machine, the more beefing up needs to be done.
As KennyD points out, for snow, if you are using a spring-tripper then you won't have those sudden impact shocks from suddenly hitting a curb, fire hydrant or lip of a ManHole cover. Those are the shock loads that bend metal.
In snowy conditions, under normal plowing, CUTs and SCUTs are going to lose traction way before they bend frames.
I appreciate your concern, and even respect your idea about trying to connect to the FEL mounting point. Would it be strong? heck yes it would.
Is it necessary, perhaps not.
Look at Dirt Dozing for a moment. Now there is a case where , with the blade locked rigid, and cutting into vrigin soil, with good traction, you would be putting some real load onto the connection points.
I don't know a whole lot about Deere's set-up on their front hitch systems, so I will defer to the experts, but, I would suggest you poking around their website, even going to a showroom, and check out how they connect their front hitches.
I'm not so worried about constant plowing loads on my machine, and new blade set-up for several reasons: I am primarily going to use it for snow, or loose material. My machine is going to "break traction" (slip) far before I break anything metal.
I'm not trying to tell you to build something flimsy, but think it through, and take a look at what the factory does.
Hope this helps.
/ Deere Front Blade #13
Manitou said:
Northstar....... I have a series "74" blade with all the mounting gear forsale very reasonable. The only problem is I live on Manitoulin Island. PM me if anybody is interested. Garry
I also have a JD front hydraulic angle blade with full frame and mounting brackets for the 50 series tractors. It's a JD model #375. It would be quite easy to adapt it to just about any tractor and I would let it go for $300. For anyone in the S.E. Missouri, S. Illinois, W. Kentucky or S.W. Indiana area that is interested I live pretty close. (didn't mean to turn the thread into a classified ad...hope it's OK to mention it here.)
/ Deere Front Blade
I was thinking that the frame for the blade needed to be attached further back on the tractor because that looks to be the way that the Deere factory blade is set up. But after reading what people have posted here I am starting to think that it may not be necessary. I just assumed that the Deere factory blade was ment for moving snow. I now suspect that it is also ment for moving dirt. If that is the case, I will go with something similar to one of the several excellent set-ups posted here as I plan to only use it for snow. Thanks everybody.
2014 Dodge Charger Sedan (A59231)
2014 Dodge Charger...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
2008 Ford Explorer SUV (A59231)
2008 Ford Explorer...
2016 Volkswagen Jetta Sedan (A59231)
2016 Volkswagen...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
