Deere Cool-Gard II equivalent
/ Deere Cool-Gard II equivalent #21
Deere used to label some of their 0W40 oil without the "synthetic" wording on the front. Some was even labelled "semi-synthetic" . I know this because I bought 10, five gallon pails and thought I was getting screwed.
I couldn't get a satisfactory answer from a dealer so I called JD, got the the oil engineering guys and they said there are some labels around that say semi-synthetic or even nothing about origin on the label. Oopsie. But rest assured, if it's 0W40 it is a full synthetic and it's all the same stuff.
After opening, using and smelling it, I would say that is true. FYI
/ Deere Cool-Gard II equivalent #22
Depending on the Deere/Yanmar machine series, the 50,55,56 Series and the 70 Series use 10W30 diesel for summer and 5W30 for winter. I've not looked into the 90 Series.
You can run 5W-30 year-round in those. The second number is really what dictates performance at higher temperature, and both products you're comparing are -30's. That's why they have the same max temperature in the graphic.
The only penalty for running 5W-30 over 10W-30 in summer is slightly higher oil consumption. That's because at any temperature up to their crossing point, the 5W-30 is a bit thinner than 10W-30. That's also why it stretches into lower temperature.
... and this is why most of the recommendations for the newer machines show 0W-40 covering the max temperature range. These old -50 and -55 machines would probably also include that in their recommended options, if such a product existed in the 1970's and 1980's, when those machines were introduced.
In any multi-weight oil, the first number is "cold" and the second number is "hot". It's not that the oil thickens with temperature, quite the opposite, but that it performs similarly to a straight 30-weight or straight 40-weight oil, when hot (and similar to straight 5-weight or 10-weight when cold).
/ Deere Cool-Gard II equivalent #23
For temps above the 86F, the Deere chart I posted says to use SAE 30. The Yanmar chart doesn't say anything. For the 4 years running 10W30, the oil level remained the same. Nothing less. There is no oil consumption from what I can tell. I also run with the tallest possible fitting filter too.
Being up in the north, there are 2 weeks where the temps get over the temp like that. I mainly don't use the open cab tractor since it's just too hot out for me too.
