Deere compact tractor flywheel sensor and mfwd sensors
   / Deere compact tractor flywheel sensor and mfwd sensors #1
Kyle_in_Tex
Super Star Member
East Central, Texas
JD 4310,JD5420
Just wondering if anyone has found a cheaper alternative? A simple sensor like this made in Mexico should only cost a third of what JD charges.
LVA11184 is now replaced by LVA17409 and it sells for $77.75
Surely this simple hall effect sensor can be found cheaper.
Also, people have stated that after hitting a bump, their tractors worked fine. Makes me wonder if taking off the sensor, cleaning the contacts and inspecting, might work? Maybe some di-electric grease on the contacts?
Borrowed this photo from OleMiss' thread.
257113d1332278607-4610-surging-issue-fixed-forumrunner_20120320_162334-png
Part Number: LVA17409
Replaces Part: LVA11184
Part Price: 77.75 USD
Description: Sensor - SENSOR, SENSOR, HALLEFFECT(OMNIDIRE
Package Quantity:
1
All Makes Parts from John Deere Where Used
English Metric
Specification
Weight: 0.11 LBS 0.05 Kg
Technology HALL
Number of Outputs SINGLE
Maximum Temperature 100.000
Minimum Temperature -40
Air Gap 0.030 IN
Length 1.576 IN
Diameter - Tip 0.375 IN
Mounting Diameter 0.260 IN
Thread Type NONE
Mounting Style FLANGE
Connector Type PIGTAIL
Finish
Note G
   / Deere compact tractor flywheel sensor and mfwd sensors #3
I would be doing a L O T of cleaning, and adjusting before I whipped out a CC!! :confused2:
2014 Jeep Cherokee Latitude AWD SUV (A48082)
2014 Jeep Cherokee...
UNUSED Roof Thermal Insulation (A50860)
UNUSED Roof...
8ft S/A Utility Trailer (A48082)
8ft S/A Utility...
vergenes (A50657)
vergenes (A50657)
2019 Ford Fusion Sedan (A48082)
2019 Ford Fusion...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
