Deere 997 zero turn Yanmar diesel valve adjustment
   / Deere 997 zero turn Yanmar diesel valve adjustment #1
zilla24
Hello all,
Looking for some help with my 2006 Deere 997 zero turn, I bought it used a few years ago and have accumulated about 2200 hrs on it. While its down for the winter I'd like to do some PM work, specifically adjust the valves. If anyone has some guidance on how to set TDC and how to proceed I would greatly appreciate it. I have looked in the owners manual and have found the clearances (intake/exhaust) both to be .002-.003".
   / Deere 997 zero turn Yanmar diesel valve adjustment #2
Which engine do you have?
31hp Yanmar, 3TNV82A
   / Deere 997 zero turn Yanmar diesel valve adjustment #6
I did it a few times on the 240D in the 25 years we owned it and a couple times on the 220D. Use a wrench on the pulley at the radiator end of the engine to turn the crankshaft or good tension on the fan belt and just use the fan blades. That's what I did on the 240D because getting at its nut on the pulley wasn't as easy.
Just watch the valves re what they're doing. All you need is for both to be closed when checking the clearance. Find the firing order. Once you find the 1st one, you'll then know which one will be next.
Dad used to do mechanical valves while the engine is running. It's dicey. Think most recommend doing them cold.
Ralph
Wanted to thank everyone for their help, I had some time this weekend and went ahead and adjusted the valves. Valves were a tad loose at .009-.010", I read in the operators manual they should be .002-.003". Adjusted to .003" and fired right up. Can't really tell much of a difference in sound but at least I know its where its supposed to be. Now if I can just chase down my intermittent shut-down problem...
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2014 FORD F-550 ROUSTABOUT(INOPERABLE) (A52472)
2014 FORD F-550...
John Deere 9620R Tractor (A53342)
John Deere 9620R...
New Long Forks (A53002)
New Long Forks...
