Enimo
I have a 955 that was running perfectly two days ago. My brother-in-law was using it at his place and could not park it inside that evening so he left it outside. He lifted the seat forward and it poured rain that night. Went back today to use it and it will not turn over. I met him there and this is what I know. The battery is good as I took a brand new one to make sure. Good continuity from battery ground to frame and from battery to starter. When you turn the key there is no click nothing. You can turn the lights on and when you turn the key they go out. Sounds like a short to me or possibly the starter. I tapped the starter to see if it may be hung up, it did nothing. I removed the starter completely and turned the key and it did exactly the same thing. All the gauges work and the lights go out when I turn the key. So, I know it isn't the battery or the starter. My guess is the ignition switch or a safety switch somewhere. Any ideas other than jumping each safety switch to see if one is bad (corroded, loose, etc.)? Many thanks for any input.
