Deere 850 Compact Tractor Torque specs
   / Deere 850 Compact Tractor Torque specs #1
rascal810
GC2300 and many others :)
Cant seem to locate my manual wondering if anyone would know the torque specs for the rod caps, flywheel, main bearings and main holder bolts for a deere 850 compact utility tractor. Also does the f on the mains stand for flywheel or front? Machine shop that I took part too took a while longer then expected cant remember for sure on that one anymore. I found the torque specs for the head elsewhere. Thanks
I found the torque specs if it helps someone else someday. 41 ft/lbs on the rod, 48-52 on the main bearings, 59 on the main bearing housings to the case, 44 then 88 then 118-133 ft lbs on the head. Also the f goes towards the flywheel on the main housings and the writing on the rods goes towards the flywheel.
   / Deere 850 Compact Tractor Torque specs #3
The nice folks at 1-800-522-7448 can send you a service manual for a very reasonable rate.
Crate for 1000 Gallon Water Tank (A47384)
Crate for 1000...
Case IH 900 6 R Planter (A50515)
Case IH 900 6 R...
Swict Q.A 66" Bucket (A50121)
Swict Q.A 66"...
Fuel Tanks and Ladder (A47384)
Fuel Tanks and...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
John Deere 652R (A50121)
John Deere 652R...
