Deere 820 Started Smoking.....Please Advise
   / Deere 820 Started Smoking.....Please Advise #1
cartod
Platinum Member
Northern, West Virginia
JD 4066, 1023
My deere 820 was making oil and was run this way for a while with way too much oil. After I replaced the fuel pump and changed all the oil out, the tractor is no longer making oil, but it is smoking pretty good out the tail pipe and the blow by tube. No loss of power is noted and the smoke is not real thick, just annoying. The tractor only has 1450 original hours, it sat for its last life. Any help on what to do next would be much appreciated.
   / Deere 820 Started Smoking.....Please Advise #2
I'd suggest to check inj pump timing and put tractor to "work" for several hrs then see if smoke clears up.
   / Deere 820 Started Smoking.....Please Advise #3
Agree with Tx Jim
Might check air cleaner also.
Good luck
Don
   / Deere 820 Started Smoking.....Please Advise #4
If the tractor was run long enough with enough diesel in the oil the cylinders/rings could be worn to the point to where you will be getting blow by out the bottom and smoke out the exhaust. Run it a while and keep track of oil consumption.
2016 HINO 268 26FT BOX TRUCK (A51222)
2016 HINO 268 26FT...
RIMS AND TIRES (A50854)
RIMS AND TIRES...
2012 Porsche (A50324)
2010 FORD F150 WORK PICKUP TRUCK (A51222)
2010 FORD F150...
1994 Chevy  2500 Dually Pick Up Truck (A50515)
1994 Chevy 2500...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
