deere 755 won't crank over
/ deere 755 won't crank over #1
arbcon
all lights come on and I hear clicking-as normal- but engine doesn't crank over. I'm thinking it might be the neutral start switch because I recently had to replace a bolt linking the two hydrostatics underneath the tractor. How can I check this? The other possibility is I saw a very small puff of electrical smoke coming from underneath the left side of the dashboard. I've replaced all fuses(including a 20 amp slightly to the left of the main fuse box which was blown), and tapped the starter slightly with a hammer. No further smoke...all connections tight. The tractor's electrics look fine otherwise. It ran two days ago just fine. It's in agarage..all nice and warm. Please help if you can...John
/ deere 755 won't crank over #2
measure the voltage at on the starter while you crank and get back to us with!
Wayne
ok....I'll do it...john
/ deere 755 won't crank over #4
Hello
I haven't seen fuses smoke, they might but I haven't seen it.
I would be looking for a bad spot in a wire that shorted causing the smoke.
Good luck, might be a pain to find.
/ deere 755 won't crank over #5
Have you cleaned the battery terminals lately???
battery is constant 12.5 volts.....I hooked the multimeter to the starter(black horizontal tube to right of alternator )and get a constant 12.5 volts regardless of the key position-I tired them all-0,position1,position 2. Shouldn't the 12.5 only be in position 2? Still doesn't crank. Wayne what do I do from here?
/ deere 755 won't crank over #7
Are you sure your checking the starter? The only way to have currect at the starter with the key off it to have a stuck solenoid. If that was the case then you would have some fried wires and the battery would surely be dead. Be sure to check your battery connections and the ground to chassis. My 1070 did the same thing to me right after i got it and it was just a loose battery terminal. If indeed you did let the smoke out of your tractor, then your gonna have to chase down the circuit pathways. Get a manual asap!
/ deere 755 won't crank over #8
First, check both battery terminals, as well as the ground wire where it attaches to the frame. Remove, clean, and reinstall. Also need to start with a known good battery. Any way you can jump it with a vehicle to be sure you've got a good battery? Checking voltage across the battery isn't enough to eliminate it as a suspect. If all of the above doesn't help, try laying a screwdriver across the 2 big lugs on the starter solenoid. If you've got current to the starter solenoid, the starter motor should spin when you short between the 2 lugs. I just had the same thing happen to me, and I needed to have the starter rebuilt. One day it worked fine, the next time I went to use it, all I got was a click. If the starter spins when you cross the terminals, I'd look at safety switches and the ignition switch. If shorting it doesn't turn it, it's gonna need rebuilt.
/ deere 755 won't crank over #9
Arbcon: I'll guess/assume your 755 is similar to my 4400. On mine, the starter solinoid (or relay or whatever you want to call it) is part of the starter. If you could get a picture of your's we could tell for your.
The heave red wire is hot all the time. There is another connector that gets 12 volts on it when you turn the key to the crank position. Can you see if you are getting 12 volts to that thing when you try to crank it?
Wayne
I'll try to start it with a jump tomorrow. I pulled the solenoid and still got 12.5. I than jumped the solenoid and got 12.5. I'm wondering if the ignition switch is fried. I'll try to get a pix posted-not sure how to do that so I'll check faq's.Thanks to all for your help. i sure need that tractor running right now...John
/ deere 755 won't crank over #11
Can you get 12 volts to energize the solonoid and see if it engages?
Wayne
update...still no start...replaced the ground cable with a new one. I still have all lights working, the clicking sound. glow plug light turns off correctly. Because I hear the clicking sound, I'm, assuming that the neutral start switch and other lockouts are not a problem. I tried jump starting but with the old grounding cable. Now that a new one is installed, I'll try it again to test the battery. If still no crank, how would I proceed from this point? I'm not super literate on posting pictures, but I believe the starter solenoid is beneath and a part of the starter motor on the 755...John
/ deere 755 won't crank over #13
Sorry, I'm confused. Why did you replace the ground cable??
Is the solonoid on the starter energizing, and if it is, what is the voltage on the starter when it energizes? If it is not energizing, you need to figure out why. The glow plugs will do their thing if it is in gear or the PTO is engaged, the starter won't.
Wayne
Thanks for your diligence Wayne. I replaced the ground cable because two thirds of it was frayed. I have a friend with a 4300 coming here tomorrow morning. It appears that the solenoid and the starter are part of a single unit. We'll check the voltage on the starter wire, and also try to figure out a way to fire the solenoid directly with going through the key switch. We're wondering if the wire leading from the key switch in position 2 is the problem. He still has his eye on the start /neutral switch as the problem. Apparently on the 4300 the s/n switch has a transistor so it won't work even if jumped out. The 755 is older and may be jumpable.
we're operating under the belief that the solenoid is the outlet for the red hot from the battery. So what we will do is jump start directly to the heave lug on the solenoid as the positive and the black line on the rear of the solenoid as the negative. This will hopefully show us if the problem is a blown key switch. If no crank, we'll try to jump out the start neutral switch. Coming back to the solenoid we has 12.5 volts to it regardless of the position of the keyswitch.
/ deere 755 won't crank over #16
Personally I would start back at square one trying to troubleshoot the problem. I've owned two JD 750's and the Yanmar engines on those were pretty similar to the one on your 755.
My first step would be to PULL the battery out, take it somewhere and get it tested. I would probably give it a good charge regardless whether you think it needs it or not. A fully charged battery should read about 13.8VDC with no load. So, when you put it back in and IF it does the same thing, then you have eliminated the battery as the cause of the problem.
Next I would double check all the major connection points on your heavy cables, both positive and ground wires, plus all the lighter gauge wiring to/from the solenoid and the ignition switch. Thoroughly clean as many connections as you can see while you are looking them over. If you see any in-line connectors, pop them loose and have a good look at the blades/pins. Sometimes they can get pretty corroded if a contaminate gets inside it. If the engine still won't crank, then you have pretty much eliminated the wiring and connections (with one exception I will get into later on).
The fact that you can hear the solenoid clicking tells me that most likely all of the safety interlocks are working correctly. If you heard no clicking when you turn the key, then I would say you would need to investigate all the safety switches/interlocks at this point as the potential cause, but that doesn't seem to be necessary in this case.
Since the solenoid will click when you turn the ignition key on to crank it, I think you can eliminate the ignition keyswitch. IF you heard nothing click when you turn it, then at this point you should measure the contacts on the switch with an ohmeter to see if they are closing. Since the contacts seem to be closing in your ignition switch, I think you can eliminate that as the cause of the problem.
That's getting down to just a few things left. :) Before you do anything else, try this: Turn on the ignition key and HIT the STARTER MOTOR solidly with a heavy rubber mallet with the keyswitch on, or maybe use a small hammer. Just don’t hit it hard enough to break the cast housing. If the starter motor magically spins over, then you have the same problem I had on my 750.
You're correct that the solenoid is integral with the starter motor. I'm going by memory here cause I had to pull the starter off of my 2nd 750 and tear into it. It turned out to be ok actually, the starting problem I had with that tractor was an altogether different issue that I will go into in some detail below. If you must pull the starter off, then do it. It's not that hard, if I can do it I'm sure you can!! :)
The contacts are inside it on the end of the starter opposite of the reduction gear. When the coil is energized, the plunger slams the contacts together completing the heavy current path to the starter motor. Check these contacts, clean if needed. IF that’s working ok, and the contacts are in good shape, then its looking like the problem could be the starter motor itself. You can benchtest the starter with a spare battery, or a battery charger, just to see how well it runs by making the starter motor spin over while sitting on the bench. It's DC so it can spin either way, depending on how you connect it to the power supply. But, to be safe, you should connect it + to + and - to -. Also, watch for the motor to jump when you put 13 volts on it, it has a LOT of torque and it can jump off the bench if not clamped down good.
Anyway, to get to my last point the guy at the starter shop had seen my problem before. The solenoid on mine would click, but not turn the starter over (mine was doing the same thing yours seems to be doing). I told him I could bump the starter with a hammer (with the ignition keyswitch in the crank position) and it would spin over. He fixed me up an extra relay, told me how to wire it to the solenoid, and said it would fix it. Well, it worked like a charm and it cranked fine everytime after that. I’ve kept in touch with the current owner of that 750 and he says it still cranks with no problems whatsoever.
This problem was fairly common and is the result of some design flaws that are also seen in other tractors. It's a combination of wiring that was undersized, and poor connections over a period of time. To be more precise, some of the wiring on a good many JD tractors should have been made a bit larger. The undersized wire will increase the resistance of the wire and at the same time increase the voltage that is dropped across the length of the wire. Also, over the years the wiring connections can work loose, or just build up some slight resistance from light corrosion. On my tractor, these voltage drops (both in the wiring and in the connections) combined enough to decrease the voltage that was getting to the solenoid and starter. This would not let the solenoid slam hard enough, nor would the starter motor have sufficient current to spin the diesel motor over. Remember, this wiring resistance and any resistance in connections will drop the voltage slightly and at the same time will limit current flow to the components it's going to! When you’re cranking a cold diesel motor in the winter, you need EVERY amp you can get to the starter.
Hopefully by now you will have found out what's wrong with it! Good luck and let us know.
/ deere 755 won't crank over #17
12 VDC with all the current you should need is on the starter with that large RED wire. Yes, as I said earlier the starter has an integral solonoid. You need to see if that is getting 12VDC to it and if it clicks, what the voltage is now on that large red wire once it clicks. It could easily be a neutral safety switch.
Wayne
Special thanks to Wayne and Kebo-the problem was in the orange wire from the keyswitch to the solenoid. We got signal at the switch, couldn't see it at the solenoid, and so we jumped and it fired up. We put in a new iwre with a 10 amp fuse in it. We're working now on the hydrostatic linkage beneath the tractor. We get drift backwards and forwards when we shouldn't. Again, thanks to everyone for helping me at a tough time. We've been hit hard here with weather, and you helped get me through it. I'll pass the favor along to someone in your honor...John
/ deere 755 won't crank over #20
glad you got it fixed. i had that problem and it turned out to be a loose neg battery cable inside the lead cable clamp. i caught it smoking. changed both cables, good to go.
