Deere 5500 Clutch Adjustment / Service Manual
   / Deere 5500 Clutch Adjustment / Service Manual #11
Wondering if anyone know how
   / Deere 5500 Clutch Adjustment / Service Manual #12
It's not complicated. There is a tin cover over the transmission. Remove four bolts and the cover. This will expose the rod and clevis that needs to be adjusted. Remove the pin, unscrew the clevis a couple turns at a time until you achieve an inch or so of free play on the pedal. If that solves your problem, then you're good for a while. If you still have clutch problems, adjustment may not be the answer, so maybe you should plan on a clutch replacement.
2013 Chevrolet Impala Sedan (A55853)
2013 Chevrolet...
UNUSED Wheeled Dump Hopper (A47477)
UNUSED Wheeled...
2012 LAMAR TRAILER 20 T/A UTILITY TRAILER (A55745)
2012 LAMAR TRAILER...
STORAGE FEES (A56138)
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A54814)
2016 Ford F-550...
44029 (A51692)
44029 (A51692)
