Deere 5420 clutch slip and replacing
   / Deere 5420 clutch slip and replacing #1
Rmart30
Platinum Member
Alabama
Currently have Kubota L4600HST, Kubota M7040, Kubota M8540, two Massey 265's, Massey 230, ...... Had Long 510, Mahindra 3510.Ford 4000, Deere 4230.
Gotta buddy who bought a cabbed 5420 a few months back. previous owner said a clutch had been installed in the last yr or so before selling. My buddy has used it for a few months and now its getting hard to go in gear and grinding. They split it and just by looking at the removed clutch can see nothing wrong with the clutch or pressure plate. They said linkage adjustment was ok and it was being fully engaged.
ideas or thoughts?
Also, from the looks of it the cross shaft the throw out bearing is on has to come out to change it out. Which looks as though the cab has to come off and fuel tank removed to get that pin out. Anyone confirm that before i go look at it for him?
   / Deere 5420 clutch slip and replacing #2
Slipping clutch plate is normally caused by insufficient clutch pedal free travel or weak pressure plate springs. Throw out brg should be R&R without removing operating shaft.
   / Deere 5420 clutch slip and replacing #3
IIRC there are three bolts that connect the "fork" to the shaft, remove these and the fork will rotate enough to allow the throw out bearing assemble to come off. The bearing and collar are press fit to the sleeve.
If the shaft has to come out (maybe to replace shaft bushings) IIRC, you can do that by removing the left front cab mount. Be sure to support the cab corner.
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
UNUSED JCT QUICK ATTACH 72" HYD 4N1 COMBO BUCKET (A51244)
UNUSED JCT QUICK...
SDLG WHEEL LOADER FORKS MAST W/ 48" FORKS (A51242)
SDLG WHEEL LOADER...
2014 CATERPILLAR 259D SKID STEER (A51242)
2014 CATERPILLAR...
Diamond 5' Heavy Duty Excavator Mower (LIKE NEW) (A50774)
Diamond 5' Heavy...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A52128)
3-Point Hitch Root...
