Deere 5300 M4WD water pump rebuild
   / Deere 5300 M4WD water pump rebuild #1
jonathanstarr
Kaupo, SouthEast Maui, Hawaii
John Deere 5300 4wd
Need to rebuild the water pump on 1994 5300 tractor. We have the rebuild kit. We're having a hard time trying to loosen the water pump from the front of the engine. After removing the nuts, the pump is on very tight. How can we get it off without using the big hammer?
   / Deere 5300 M4WD water pump rebuild #2
Check, then check again, run your fingers all the way around the flange, being double sure you haven’t missed a bolt, then usually a light rap with a deadblow hammer will break the sealer loose, use light blows, you’d hate to have to buy a whole pump because you rushed
   / Deere 5300 M4WD water pump rebuild #3
Did you remove the "nut" there are bolts and one nut
Thanks. We'll pull the radiator and try again tomorrow. I think we now have everything we need to accomplish the pump rebuild it it comes off with minimal persuasion. We could have missed a nut the first time around.
Got the water pump off. One bolt had corroded (27 years) and the head broke off when we tried to remove it. That bolt was locking the pump in place, and we had to drill it out, starting with a long small diameter bit and increasing to close to the bolt diameter.
Then the pump body started to move a bit and we could get it off. The remaining bolt was like a thin piece of tubing, and screwed out with a vise grip without any damage to the threads!
2018 DRAGON 130 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 130...
JCB 409 AGT4 WHEEL LOADER (A51246)
JCB 409 AGT4 WHEEL...
UNUSED AGT SAWMILL MODEL - YC32G (A51248)
UNUSED AGT SAWMILL...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
2010 Turfco...
2025 Swict 72in Bucket Skid Steer Attachment (A51691)
2025 Swict 72in...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
