Deere 5100 M vs NH T5060
   / Deere 5100 M vs NH T5060
I haven't run a NH before, but the 5M's open station or cab control layouts are a lot better than a NH any day. Deere is still in Interim Tier 4 not full Tier 4 quite yet. For regens on the DPF you can regen while you work, or when it needs to regen you can disable it and come back to it later. Kind of like a remind me later function, but it won't remind you so you can do it later. I believe you can just put it in the parked regen and leave it and it will do its thing until its done or do it on the go in the auto mode.
The Deere salesman told me that if you run it in auto it regenerates
Without the need to stop. However, if you run it in off mode
you will have to stop and turn it on and wait.
I don't disagree that the JD layout in the cab is superior.
However, is it worth another 10 to 12 thousand for a comparable
tractor. I suspect the resale on the JD is a little better.
   / Deere 5100 M vs NH T5060 #13
i say look at the kubota 110 or the 126 they might be a little cheaper the 3pt lift fel lift spec the same as the 5070 with the 3pt lift assist cylinders
   / Deere 5100 M vs NH T5060 #14
The "block style" hose connector for the loader is called a Multicoupler by John Deere. If you are going to take the loader off a lot, I highly recommend it. My JD6415 has the third function and it beats having to mess with six QCs any day. Expensive to retro fit, but not bad when buying new.
   / Deere 5100 M vs NH T5060 #15
Thats a big price difference in price. I would get the New Holland. The New Holland will last just as long if not longer.
Where can I find the torque comparisons? NH doesn't provide much info only notes a 29 percent increase as I recall.
   / Deere 5100 M vs NH T5060 #17
tractortestlab
In case anyone is wondering, I bought none of the above and went with a JD6330.
   / Deere 5100 M vs NH T5060 #19
How is the 6330 treating you?
Cat TH407C Telehandler (A53472)
Cat TH407C...
2017 Kawasaki Mule (A55973)
2017 Kawasaki Mule...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A51691)
Generac Yanmar...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
Longhorn Steer Skull Art (A55853)
Longhorn Steer...
TROYBILT TB685 EC WEEDEATER (A54757)
TROYBILT TB685 EC...
