Oil & Fuel Deere 510 industrial, runaway diesel
   / Deere 510 industrial, runaway diesel #1
turboseamus
I just bought a Deere 510 industrial tractor, loader/backhoe. It doesn稚 run currently, the guy I bought it from started to take the injection pump out but got sick so never finished the project. He said he was digging a stump out and the engine started to runaway and he got it shut off by stalling it out. I have been doing a little reading, and injection pump seems to make sense to a point, but sounds like most people say the Roosa-master pumps don稚 really runaway. The other part to this is he said he had just had the head gasket replaced before this happened, less than an hour run time since. This is a non turbo 4.4L 4 cylinder, pretty basic. Just wondering if there was something that could have gone wrong with the head gasket replacement that could cause runaway, or should I just send out the pump? I知 a car mechanic and I know how diesels operate for the most part, but I haven稚 really had to work on them much.
   / Deere 510 industrial, runaway diesel #2
The governor retainer ring in the injection pump has failed. It is a common failure, a runaway is a possible consequence of that failure.
   / Deere 510 industrial, runaway diesel #3
They will run away with fuel or oil. I could see a head gasket problem making it suck oil. Enough to make it run away? I wouldn’t think so as I think it would just suck oil into one cylinder. It could be several things.
So that痴 an injection pump rebuild then. Does anyone know a reputable place to send it to?
   / Deere 510 industrial, runaway diesel #6
You might send a PM to member thepumpguysc as he has posted good information about injection pumps, and might be of some considerable help.
Wish you well sorting it out, and :welcome: to TBN
As an update, I took the injection pump apart and the weight retainer plastic ring was broken. I replaced it with the Stanadyne solid replacement and reseal kit. Put it back in and it seems to run great.
   / Deere 510 industrial, runaway diesel #8
I'm glad you were able to fix it.
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
John Deere Pro Gator (A50123)
John Deere Pro...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2019 Genie GTH-844 (A50123)
2019 Genie GTH-844...
1998 Talbert TDW-35S-HRG-1-T1 Detach, GVWR 84,300 (A52384)
1998 Talbert...
