Deere 5055E
   / Deere 5055E #1
dzul25
washington
john deere 5055E
I have a question and i know the majority answer will be to buy a new tractor but i shall ask anyway. Is there a larger engine that can mate up to the 5055e? Curious if the larger 4.5L powertech would bolt up. I know it is a larger engine but mechanicaly would it bolt up to flywheel housing and transmission of the original 5055e. Also are there older engines that would bolt up?
thanks in advance for your information
   / Deere 5055E #2
You could call Martin Farm service in Mount forest, Ontario Canada. Maybe hide your caller I.D. If anyone knows, they would, being JD Ag tractor experts. JD wouldn't have a clue and won't even entertain conversations like that.
   / Deere 5055E #3
Not trying to take this off topic but have you considered talking to an injector shop? A lot of times they can significantly increase HP and torque. Then you are only out the injection system and probably cooling/radiator mods.
   / Deere 5055E
i will try and give them a call and see if they have insight
   / Deere 5055E
@RNeumann know any injector shop guys that would be knowledgeable in E. washington or Idaho?
   / Deere 5055E #6
   / Deere 5055E #7
The 5055E is one in a series of tractors starting with the 5045E and going up to 5075E (from memory) all with the same engine. The difference is a different turbo and some bells and whistles like different size tires or number of hydraulic outlets. I suggest you start by looking into a different turbo and see if it will do what you are trying to accomplish.
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
1997 Mercedes Convertible (A48082)
1997 Mercedes...
2017 Wacker Neuson ST31 Compact Track Loader Skid Steer (A49461)
2017 Wacker Neuson...
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
