deere 47 blower on X585
   / deere 47 blower on X585 #1
BaerEssentials
Hi folks,
Simple question... I am comsidering purchasing a new 47 snowblower for my X585 deere tractor. I have a moderately inclined 200 foot concrete driveway that I just spent, what I consider, alot of $$ getting installed. I am worried that the blower will mark up the concrete. Yet, I am also concerned that it won't clear the snow all the way to the concrete; i.e. it leaves a layer of snow.
Will you knowlegable folks shed some like on these concerns?
Thanx
Scott
   / deere 47 blower on X585 #2
I have the same set up as you do. My blower works well and doesnt leave marks on the concrete. It takes a bit of practice to get the skid shoes (I think that's what they're called) adjusted to have the right amount of distance beween the bottom of the blower and concrete. I find if I have the shoes provide about an 1/8th of an inch clearance and "float" the blower, it works great. I in essense scrape the concrete with no marking.
Good luck!
   / deere 47 blower on X585 #3
If worried about marking the concrete, get some wheels for it.
The X585 I believe has some down-pressure on the front attachments even when in "float". So dropping it down on wheels (similar to the brush attachment) may be the perfect solution.
You may make more marks with the tire chains than the snowblower. :)
Thanx for the input.
I went to the dealer today to check out the 47. I live in Pittsburgh suburbs and we don't get a crazy amount of snow, just your average 6-9" a couple times a year. Everything else in 2-3". The guys at the dealership told me that the plow might be better suited for the area cuz th 47 might not do well in 2".
Any thoughts? Should I go with the plow instead? (they have a JD rubber stip that will attach to the bottom of the plow to protect the driveway suface. kinda slick)
Thanx again
.. actually I would love to get the 60 rotary broom. It's like 5k, though.
   / deere 47 blower on X585 #6
My drive is similar to yours and I have no problems. However, there is something to be said about the small amount of snow you referred. I suspect that if you typically are getting 2-3 inches at a time then a blade would probably work better. The blower doesn't seem to do as well with small snowfall like that. However, with 3 inches or more the blower is great. With the lake effect snow machine kicking in here in West Michigan, you can get up to 20 inches over night. Then the snow blower is a lot of fun! We had over 130 inches last year. Way above the normal snowfall.....
   / deere 47 blower on X585 #7
That broom does do a good job. And other uses for it besides snow. I use it to clean up hickory nut husks and sticks at times, and sweep off the drive at other times, including the snow when it is light.
   / deere 47 blower on X585 #8
I LOVE my rotary broom on my X475. Its the absolute best snow machine in the 2 inch snows. It scrapes the sidewalk BARE, and sweeps all the dirt away with the snow, so you are left with a sparkling clean sidewalk/driveway.
I have a 47 Blower that goes on for the deeper snows!!!!!:cool:
Watched every Youtube vidieo of deeres blowing and plowing. still can't decide between the two.
for those that have the 47 blower... is it true that it is less that "ok" for light snows? i.e. does it do a satifactory job w/ 2"?
   / deere 47 blower on X585 #10
I have a 47 and have used it for everything from 1 inch up. Granted, it isn't throwing the amount out of the chute as a 6 inch snowfall, but it does the job. I usually go a little faster with light snows.
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
378812 (A51573)
378812 (A51573)
NEW Woods 6ft Finish Mower (A55218)
NEW Woods 6ft...
2015 New Holland Boomer 47 4WD Agricultural Utility Tractor (A53421)
2015 New Holland...
2002 MACK RD688S ROLLOFF TRUCK (A51406)
2002 MACK RD688S...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
