Backhoe Deere 46 backhoe
/ Deere 46 backhoe #1
deere_x475guy
Eaton Rapids, MI
JD 4110
Hi gang, I have been looking at the Deere 46 backhoe and the woods model that fits my 4110. I am wondering if anyone here has experience with both models to help me compare. I see that Deere is rated a little higher in capacity and the sales guy claims the hydraulics are alot smooter than competitors....of course he would say that....wouldn't he????LOL
Anyway I have a lot of drainage I need to correct and several small ponds along with waterfalls I will be building. I will make my own mechanical thumb to aid in picking up and placing some of the stone that will be used in the construction.
Any feedback is appreciated.....Later
Bob
/ Deere 46 backhoe #2
My 2520 with the 46 backhoe was delivered last week, and I must admit that I am more than pleased with the performance of both the tractor and the 46bh.
I have used a kubota 2250 with the Woods 3pt backhoe extensively in the past, and found it to be competent and able. I've no complaints, it served me well. My only gripe was the sometimes frustrating process of mounting/unmounting the 3pt set-up, sometimes it only takes minutes, other times it has taken hours...frustrating.
My first impression of the 46bh was one of surprise. I expected performance to be similar to the 3pt Woods, but found that I was impressed by the performance of the JD product. I feel that the hoe maneuvers more rapidly, the controls more precise and controllable, and that I have more fine control of the hoe. It is my impression that the 46bh has more capability than the Woods, and it's operation seems smoother to me.
Removal and re-installation of the 46bh is a pleasure, especially with my previous experiences.
/ Deere 46 backhoe
That sure is a sweet looking setup you have gunmaker and thanks for the feedback. The dealer said it would take 2 to three weeks to get it in and then I am sure another week to work in into the schedule to mount it. Do you mind if I ask what size bucket you have with it and what type of soil you have dug with it so far. Mine ranges anywhere from sand/gravel with some bolders to heavy clay. I figured I would get the 9" and 13". The 9 I would use for shallow trenching and digging in the tuff stuff.
Bob
/ Deere 46 backhoe #4
I have generally rocky soil, with some small boulders and heavy clay. I choose the 13" bucket from previous experience, and found it to be perfect for my needs. I may also pickup the 9" bucket in the future for trenching.
Sounds like you're pretty well squared away.
It took only 2 weeks for the tractor to make it to the dealer, but 5 weeks for the 46bh. Set-up only took 1 day.
/ Deere 46 backhoe #5
Now you've got me all excited, my 46 should be here any day now. At a high level, what's the process for removing and installing the backhoe? I've thusfar been impressed with how quickly I could pick up the other JD components (the FEL is on and off in just a few minutes now).
I'm very familiar with the NW NJ soil type - I grew up in Long Valley. Compared to that soil the stuff I've got now should be nothing!
/ Deere 46 backhoe #6
Better with practice, but 10-15 mins safely.
1-Center the boom, extend the dipperstick, and lower the boom so the bucket top edge is parallel to ground.
2-Pull 2 front pins from hangers.
3-Lower boom and stabilizers evenly, to lower the front bh frame to the ground and take weight off draft link pins.
4- Drive ahead 6-8" til subframe hooks clear draft links, lower main bh frame to ground.
5-Disconnect Power Beyond hose from bh, and re-connect to tractor.
6-Go get new toy!
Grew up in Andover...getting awfully crowded around here these days! Used to be more cows up here than people.
/ Deere 46 backhoe #7
There's just something to be said about "matched" equipment.
That hoe is a very nice hoe. If you were to look into the
specs, I think you will find it even out digs the old number 7
hoe on paper.
/ Deere 46 backhoe #8
I have a 4110 with a 410 loader & 46 hoe. It is very impressive and easilly digs out rocks and small stumps. It will throw you around a little however. It takes a little getting used to and is much different than the big TLBs i drove inthe military.
/ Deere 46 backhoe #9
I have the 4110/46 combination as well. Very nice ballance between tractor and Backhoe, a fine setup. I think you will find the 13" bucket effective for most situations. I dig in hard clay, no rocks, just stumps and roots.
Cliff
/ Deere 46 backhoe
Thanks everyone for taking the time to reply. I do have another question though. When you drop the 46 BH does the subframe come off also. If not how much ground clearance is lost?
TIA
Bob
/ Deere 46 backhoe #12
Yes it does, on the 46bh, the hoe and subframe stay together as a unit. Makes the on/off task fairly easy.
/ Deere 46 backhoe #15
Two notes:
First, the only difficulty I have installing the 46 BH is removing the 3PH 1st, when I've been using 3PH implements. Installing the 46 is a breeze, on anything close to a level area, with a little practice.
Second, WATCH OUT for how FAST that boom moves, especially when fully extended dipper. Get it out away from anything and practice with it slowly. Bruises to siding, trees,... can happen really fast. Bruises to people and pets are much more serious.
Have fun. The 46 is a very capable tool.
Tom
/ Deere 46 backhoe #16
Just as a reminder about ground clearance. Remember that although the subframe (when the BH is on) reduces the ground clearance, that reduction is in the form of two stout steel bars running fore and aft. If you hit bottom, it doesn't hurt the tractor any unless you've been droped from a ways up. Scraping over a rock isn't going to hurt the subframe any.
Cliff
2015 RAM 4500 HD 4x4 Service Truck (A62613)
2015 RAM 4500 HD...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
YANMAR VIO35-6A EXCAVATOR (A63276)
YANMAR VIO35-6A...
