Deere 455
   / Deere 455 #1
BrisMatt
Australia
JD 455
I have a deere 455 with no serial plates on it, its a very rough looking machine. I need to replace the ignition module on this machine and have read that I first need to know the serial number of the machine. What would happen if I bought a module that suits a different serial number machine? Would it still work? The ignition module I have is badly weathered and is no longer engaging the mid PTO
Matt
   / Deere 455 #2
Hi Matt. I,ve got a 455 as well, and from what I have learned about mine, the mid pto is engaged by the pulling up on the switch on the left of the dash, and a coil that is located at the back of the tractor. I have had to replace that coil once to repair my mid pto engagement. As far as I know, that circuit does not run thru the ignition module. Are you handy with a test light ? Try and get a copy of the wiring diagram and trace thru that. Did the mid pto ever work since you bought the tractor ?
2022 Club Car...
Kubota B2100 4WD Compact Tractor (A49251)
Kubota B2100 4WD...
John Deere TX 4x2 Gator (A47307)
John Deere TX 4x2...
Wood Chuck 12in Wood Chipper (A49251)
Wood Chuck 12in...
Massey Ferguson 283 2WD Tractor (A49251)
Massey Ferguson...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A46684)
2014 Ford F-150...
