Deere 4510 front axle drive
   / Deere 4510 front axle drive #1
BKBrown
Madison, VA
Ventrac 4231 Gas
I have a neighbor with a 4510 and the front axle drive has a seal leaking where the axle meets the drive unit (hope I have used proper terms).
I can't find a repair manual for this tractor and wonder what the procedure would be for getting it apart and replacing the seal. Also, if there is any reason it can't be done by a decent "shade tree mechanic".
Thanks in advance !
Just curious why there would be 70 views and not 1 reply ??
   / Deere 4510 front axle drive #3
You can order a repair manual from your local Deere dealer either in print or on CD ROM. They are also available to order on Deere's website at http://techpubs.deere.com/. A parts catalog will give you the breakdown of components, and they are free of charge online at jdparts,deere.com, just have to register.
Thanks, I found that and the neighbor ordered a CD.
I had not found the parts catalogs - I'll look.
THANKS again !
   / Deere 4510 front axle drive #5
Here's the parts schematic Parts key #11 LVU25945 SEAL, OIL ADD 33.88 USD
parts key #35 LVA14181 SEAL, ASM ADD 33.11 USD
Thanks - I found that. It is #11 that is leaking.
The question remains about disassembly. It is not clear what needs to be removed to get #9 and #16 apart.
I can usually figure it out from the parts exploded view, but it is not clear in this case and it is not my tractor.
I hope the CD with service manual explains the procedure.
HANGCHA CPCD25-XW98C-RT4 STRAIGHT MAST FORKLIFT (A51406)
HANGCHA...
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 72in Dual...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A53843)
RIPPER ATTACHMENT...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
230112 (A53422)
230112 (A53422)
New Holland TS6.130 4WD Utility Tractor with Slope Mower (A53421)
New Holland...
