Deere 4410 hst trans won't start issues
   / Deere 4410 hst trans won't start issues #1
LSBrick
2001 deere 4410
The other day tractor started right up and throttled up fine. Loader hyds and mid deck lifted fine. Had no forward or reverse pushed pedals and nothing. I checked seat switch and still nothing. Codes were flashing did not copy at that moment. Shut off to come back to it later. Come back in half hour go to start it now won't start or crank just a click at what I am sure is fuel solenoid on injecyion pump. Clicked several times. called it a day. Next day come out and now key turns not even a click. Checked battery with load test and it tests fine. Cleaned terminals and still nothing. Dash lights come on, glow plug lights up but nothing is flashing for codes. Not sure if anyone can point me in the direction of order of what to check and test first. I do not have a service manual and am off tomorrow so would like to see if I can diagnose the issues. First the no start then can get back to why it did not move. Thank you.
   / Deere 4410 hst trans won't start issues #2
Just a first thought.. that your forward and/or reverse pedals are stuck in a position that won't allow the safety bypass switch to allow it to start.
Had a similar thing happen.. puzzled to no end. But found a stick lodged in the linkage. Removed that stick and the pedals moved freely, and back to neutral position.
Some have had to oil the pedal pivot points to free them up.
Not sure that is your problem, but sounds like it could be.
:welcome: to TBN
   / Deere 4410 hst trans won't start issues #3
LSB - Check your messages
   / Deere 4410 hst trans won't start issues #4
Another thought is the gear selector. Mine won’t start unless it’s in neutral. The reason I say this is you first said it wouldn’t move, then wouldn’t start. Maybe the range selector is hanging up.
John Deere 455G Loader (A48837)
John Deere 455G...
2010 L3 GENERATOR SET (A51222)
2010 L3 GENERATOR...
2013 PETERBILT 367 DAY CAB (INOPERABLE) (A50854)
2013 PETERBILT 367...
2018 FREIGHTLINER 1085D DUMP TRUCK (A51406)
2018 FREIGHTLINER...
Unused 2025 40ft. Texas Pride FT835524KGN 13 Ton T/A Gooseneck Flatbed Trailer (A49346)
Unused 2025 40ft...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
