DEERE 425 W/LOADER
/ DEERE 425 W/LOADER #1
Anonymous Poster
Epic Contributor
HOW DOES THE TRACTOR HANDLE WITH ONLY 2 WHEEL DRIVE.
DOES IT TURN WELL INTO HILLS AND DEPRESSIONS.
THANKS FOR THE INFO
/ DEERE 425 W/LOADER #2
G KIBIT,
Before the four wheel drive tractor really came about,the two wheel drive tractor did just fine and still do. /w3tcompact/icons/wink.gif
Depending on what time of season you plan on really useing the two wheel drive tractor,you might want to consider a good set of tire chains and weight.
Thomas..NH /w3tcompact/icons/wink.gif
Thanks Thomas,
I will be landscaping rough terrain, moving crushed stone
on my drive and road. This winter I will be moving snow
and ice piles also. Have a 20 year old JD314 w/54" blade
that never missed a beat but I now need a loader. Am
leaning toward the Bx1800
/ DEERE 425 W/LOADER #4
G KIBIT
If you have the time check out some of the problems in which some of the gentlemen had with the BX models.
Maybe you might want to go a tad heavier model for the work in which you have line up??
Lot people have purchase those JD314 in my area years ago,and they are still zooming around. /w3tcompact/icons/smile.gif
I guess the JD318 kinda took there place now...but still JD. /w3tcompact/icons/wink.gif
Take care and stay safe.
/ DEERE 425 W/LOADER #5
If you are already leaning towards the BX, lean a little harder until you fall onto one. The difference between 2 wheel drive and 4 is unbelievable, and makes the BX a tool and the 425 a toy. Add in the 3 point hitch and it is a no-brainer; get the BX for sure.
/ DEERE 425 W/LOADER #6
G Kibit,
Since you're leaning toward a sub-compact, why not look into a full compact for just a little more money that will do a lot more and have a regular sized 3 pt. ? ? ? ?
Head on down to your local New Holland dealer and look at the TC18 with the power steering option. Many have said the front hood design makes for easier/more visible front loader work! For a little more money, you'll get a lot more tractor. The TC18 will make the BX look/act like a toy!
Good Luck, JimBinMI
/ DEERE 425 W/LOADER #7
Thank you Gentlemen,
It looks like I will go with the BX1800. My work here is
not big enough for a larger machine. All I need is the
dealer to get a loader off a slow boat from Japan before it
snows.
Gkibit Maine
/ DEERE 425 W/LOADER #8
Jim,
You are true BLUE for sure!!/w3tcompact/icons/cool.gif
If you ever decide to leave teaching you might want to consider becoming a NH sales rep. /w3tcompact/icons/wink.gif
/ DEERE 425 W/LOADER #9
Go one step up to the 4000 series, the 425 has if I am not mistaken only has a 3 pt hitch capacity for cat 0 only. this will limit you down the road, everything is beefier on the 4100 and up and by the time you load up a 425 you could be in a 4100 for a few $
/ DEERE 425 W/LOADER #10
GKIBIT,
Hope that boat steams a little faster,for winter knocking on the door. /w3tcompact/icons/crazy.gif
How many Kubota dealers in your area?
Watch out for that gentleman JinBin,for he is a true blue NH. /w3tcompact/icons/smile.gif/w3tcompact/icons/wink.gif
If your out and about in Maine be extra careful of this nasty weather. /w3tcompact/icons/frown.gif
/ DEERE 425 W/LOADER #11
I don't want to go green, orange or blue on this one. But just wanted to say don't do it. The 425 is not what you want if you are looking for a loader. The 4100 or comparable model in the other colors would be a much better bet. Let us know what you would like to do with it so we can make sure we size it right. The $ when the dust settles will be minimal. 4WD with the loader always I use it more than I would have thought.
/ DEERE 425 W/LOADER #12
Hello Gentlemen,
With your help, I bought the Bx1800 w/Loader. So far with
the light stone and landscaping chores it has worked out
well. In the spring I will be doing heavier earth moving.
It appears we will be moving snow shortly. I will keep you
updated on my progress. Thanks again for you help.
Mr. Green to Orange Gkibit Me.
/ DEERE 425 W/LOADER #13
GKIBIT,
Congratulation on your new BX1800. /w3tcompact/icons/smile.gif
I was wondering what the max your FEL can lift? I guess with the ground frozen your also at a stand still,/w3tcompact/icons/frown.gif and waiting for the snow to arrive to get some more tractor time. /w3tcompact/icons/smile.gif
Hope its a darn lot warmer up there than it is down here.
Stay safe and warm.
/ DEERE 425 W/LOADER #14
Congratulations on the new Kubota. You'll like your little Orange helper a lot. I bet you find jobs to do that you never knew were there.
Where do you live that snow is on the way (OK, a few days ago). Here in Michigan all of the Kubotas, Deeres, and Blue Machines have been working hard moving the white stuff.
Bob Pence
/ DEERE 425 W/LOADER #15
Hello Y'All,
Up here I only scraped some light snow off the drive so far.
My loam pile thawed for a couple of days, got to spead some
and sow seeds with hay cover. Not too bad for December.
The FEL shud lift 460#, no problem with a full load of wet loam. Tractors working great.
Gkibit, Maine
2 Row Cultivator (A64047)
2 Row Cultivator...
2018 MULTIQUIP TOWABLE GENERATOR (A63276)
2018 MULTIQUIP...
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
2010 Mercury 15HP Tiller Four Stroke Outboard Boat Motor (A64557)
2010 Mercury 15HP...
