Deere 4115 Power Beyond Kit
   / Deere 4115 Power Beyond Kit #1
VortecZ71
I'm picking up a 2004 Deere 4115 this week. I eventually want to install a backhoe and am aware I need a Power Beyond Kit. However, I need some help with the correct part#. Is LVB25603 the correct one for my application? How can I tell if it has dual SCV? Chris
Power-beyond kit
   / Deere 4115 Power Beyond Kit #2
Yes, I believe that is the correct kit. You have the DSCV if you have a loader, it's what the joystick is connected to and operates.
Hi Kenny, thanks for the quick reply. I do not have a loader but am hoping to install one prior to the backhoe. Is there another way to tell if it has DSCV?
It appears LVB25603 is correct if I do have DSCV. BM19290 is for older tractors that do not have a dual selective control valve (DSCV) according to that link above. It's my first tractor so I'm new to hydraulics. Chris
   / Deere 4115 Power Beyond Kit #4
Do you have the joystick on the right side, next to the seat? If yes than you have the DSCV.
You must have a loader to both counterbalance and stabilize the backhoe when using it.
Just my opinion, but that seems like a lot of money to invest into a 12+ year old tractor, your looking at about 8k or more to add both.
Hi Kenny is below the joystick you were referring to? I also understand the investment on an older machine but it is in really good shape with under 400 hours. It was a trade in by a guy who just used it to mow his property. I'm definitely looking to add the FEL. I'm not sure about the backhoe as it is expensive like you said. However, I figure if the power beyond kit is being discontinued, I'd like to buy it just so I'm setup for a backhoe down the road regardless of whether I pull the trigger on it. Chris
   / Deere 4115 Power Beyond Kit #6
Yes, you have the joystick/DSCV (dual selective control valve)
The current JD H130 loader will fit that machine, as well as the older 200cx. There are a few aftermarket options as well, but your still looking at about 3k-3.5k to add one.
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2013 Chevrolet...
167 (A52708)
167 (A52708)
US BERKEL MEAT CUTTER / SLICER (A58374)
US BERKEL MEAT...
2001 Ford F-550 Liftmoore 6036 3 Ton Crane Mechanics Truck (A56858)
2001 Ford F-550...
2004 TRAVIS BODY & TRAILER DOUBLE ALUMINUM BELLY DUMP COMBO TRAILER (A58214)
2004 TRAVIS BODY &...
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
